Page 3 of 3
Re: 2000 Bonnie SE stalling issues
Posted: Sat Apr 15, 2017 10:20 pm
by Bad67bird
:dontknow: I'll start again monday
Posted: Sun Apr 16, 2017 9:45 am
by Bad67bird
MKMike wrote:Bummer.
Well, happy Easter or Passover--or simply have a happy weekend!
No worries Mike , I've been work in on it awile now......thanx for the well wishes and hope you had a happy weekend as well
Posted: Mon May 01, 2017 7:28 am
by Jut_D_03
Lol replace your IAC dude u said you saw Improvement go from there and yes there is a wrong way to install TPS lol almost dos it and tired fuel filter?
Posted: Mon Jul 17, 2017 9:37 pm
by Bad67bird
So I got all the codes cleared and took her out on the freeway and opened her up to see what
Would happen........at 90 mph WOT the check engine light came back on and I noticed there was
A roaring sound. The code is p0300 random misfire and now when I accelerate hard , it roars like
An open breather.I'm gonna put a vacuum gage on it the see what's up.my thoughts are A : blown
Intake gasket or B: cracked intake.we all see :dontknow:
Posted: Tue Jul 18, 2017 9:00 am
by 96 SSEi
just for giggles, unplug the maf and see how she runs
Posted: Thu Jul 20, 2017 12:29 pm
by Bad67bird
96 SSEi wrote:just for giggles, unplug the maf and see how she runs
Lol been down that raod, after two new ones and now an original good one from haro.......no change
Posted: Tue Nov 07, 2017 12:05 pm
by Bad67bird
Ok I finally found the problem, the Delco ignition module that I put on last year
Had a short in it all along. I found this out yesterday when 3 cylinders mysteriously
Died. Well long story short new module on and problem gone.thanx everyone for the help
And Haro for all the parts lol.
Posted: Wed Nov 08, 2017 9:44 am
by MKMike
Bad67bird wrote:Ok I finally found the problem, the Delco ignition module that I put on last year
Did you mean to say DELPHI module?
I've had some issues with Delphi aftermarket parts but not ACDelco.
Posted: Wed Nov 08, 2017 1:23 pm
by Bad67bird
No I took Haro advise and ordered an ac delco one to
Prevent problems,but no luck lol
Posted: Wed Nov 08, 2017 2:09 pm
by MKMike
Bummer. Hope it was just a defective ICM.
There are things you wouldn't even think of which will cause ICMs to keep failing.
One thing I wouldn't have suspected is excessive AC voltage leaving the alternator.
Worse still, the ICM isn't the only component that can get damaged by this.
Just something to check.
You might read this article to get more ideas on this; article is on page 2 columns 2 and 3:http://www.wellsve.com/sft503/counterp_v7_i2_20031.pdf
