Page 3 of 5
Re: HELP ON MODDING MY 93 BONNEVILLE SSE SUPERCHERGED
Posted: Sat Jul 31, 2010 11:48 pm
by 99bonnieSE
MADDEN95L wrote:A series 1 engine don't have now topend. . It tops out at 115mph inside of performance shift . Series 2 engines 125mph dats wat gm governed them out at and gm over rates the car a lot. Stock series 2 engines only put out 225. Hp and series 1 engines only 200hp. Check dyno runs on youtube.com
SII N/A's run 205 H.P. stock and charged ones run 240 H.P. stock.
Posted: Sat Jul 31, 2010 11:53 pm
Wheel HP is 20% less than crank HP, due to parasitic losses through the transmission. If anything, GM under-rated these engines from the factory. I have never seen a Series I or Series II engine on an engine dyno. No one has ever cared enough to spend the money, from what I can tell.
Madden, we know what we're talking about as well or better than you do. A lot of us live and breathe this stuff.
Posted: Sat Jul 31, 2010 11:55 pm
by 99bonnieSE
00Beast wrote:Wheel HP is 20% less than crank HP, due to parasitic losses through the transmission. If anything, GM under-rated these engines from the factory. I have never seen a Series I or Series II engine on an engine dyno. No one has ever cared enough to spend the money, from what I can tell.
:stupid: :btruestory:
Posted: Sun Aug 01, 2010 12:31 am
by willwren
Madden, you are sadly mistaken in nearly everything you believe. Do you want answers, or do you want to live in a fantasy world?
Posted: Sun Aug 01, 2010 12:40 am
by nos4blood70
Seriously dude. Take the advice.
Posted: Sun Aug 01, 2010 12:20 pm
by MADDEN95L
I'm listen to the club members. Willwren gave me a list and imm go off his and a couple other members advice too.
Posted: Sun Aug 01, 2010 12:28 pm
by willwren
The advice given is to FIX your car and significantly lower your performance goals. Your goals are entirely unrealistic. Trust me. I have one up on ramps in my driveway right now. And another torn apart right next to it.
Posted: Mon Aug 02, 2010 8:16 am
by MADDEN95L
willwren i can only find 1 motor mount. i cant find the rest!
Posted: Mon Aug 02, 2010 9:18 am
by lewis26
If you can't even find the motor mounts, you obviously do not have a service manual, and you should NOT attempt the mods you are talking about. You lack the mechanical know how of how to do what you want to do.
Posted: Mon Aug 02, 2010 11:29 am
by MADDEN95L
i found them already on ebay last night!
Posted: Sat Aug 14, 2010 1:16 am
by MADDEN95L
Can u tell me wat performance mod can I do with my pcv on my car!
Posted: Sat Aug 14, 2010 3:42 am
by myfirstbonnie
None, there are no performance factors related to the PCV system.
http://en.wikipedia.org/wiki/Positive_C ... entilation
Posted: Sat Aug 14, 2010 9:11 am
by willwren
There is no performance to be lost or gained with the PCV valve. Where did you hear that?
Posted: Sat Aug 14, 2010 2:17 pm
by MADDEN95L
Willwren , I thought I could put one of them little 2inch cone filters on there.
Posted: Sat Aug 14, 2010 2:33 pm
by willwren
On where? You thought? Where did the idea come from? What do you think it will gain?
Posted: Sat Aug 14, 2010 2:41 pm
by MADDEN95L
Makes the pcv breathe better
Posted: Sat Aug 14, 2010 3:02 pm
by willwren
Better how? You still haven't told us where you heard this. I'm not aware of any breathing issues in the PCV system of ANY car, let alone a Bonneville.
Again, what have you heard? How do you think this will gain you power? How much power do you think it will gain?
Re: HELP ON MODDING MY 93 BONNEVILLE SSE SUPERCHERGED.
Posted: Sat Aug 14, 2010 3:12 pm
by MADDEN95L
My friend has it on his 94 caprice lt1 . He has one 2inch filter on his pcv and 1 filter on his valve cover
Posted: Sat Aug 14, 2010 3:17 pm
by crash93ssei
You will gain absolutely nothing by removing the PCV system and installing a breather in the valve cover. The only reason to do that is if you intercool your car, and trust me, you aren't ever going to do that.
Posted: Sat Aug 14, 2010 4:24 pm
by repinS
The PCV system either works or it doesn't. If your valve is bad replace it, if it isn't, don't worry about it.
