Page 2 of 2
Re: RCA Inputs...
Posted: Fri Aug 15, 2008 12:04 am
by hawkjet
Raviaan wrote:hawkjet... do you know the p/n for the terminals I need for the c215 connector? And thanks again for all the help!
I don't.
You could get some other harness (that has the right pins) at a junk yard and steal the pins from the connector.
Re: RCA Inputs...
Posted: Fri Jul 01, 2011 4:56 pm
by jlu6
FYI,
The key to using the Zune (or any other player) via an FM transmitter is to crank up the player as high as it can go without over driving the amp in the player and use the radio to adjust the volume. that way all the noise that you hear when the player volume is down and the amp in the radio is up will be eliminated. The difference is HUGE!!!!!!
hope that helps!
JLU6
Re: RCA Inputs...
Posted: Fri Jul 01, 2011 5:50 pm
by swampthing
jlu6 wrote:FYI,
hope that helps!
JLU6
That's not entirely true, some fm modulators (particularly the cheap ones like I used) will distort and sound terrible if given yo high of an input signal when I used my old one I couldn't go past halfway on the volume on my phone/ipod without mega distortion.
Personally I would go aftermarket and ditch the delco headunit altogether since nearly every aftermarket player has aux in and usb on it
Re: RCA Inputs...
Posted: Fri Jul 01, 2011 5:55 pm
by Bugsi
It is local policy here to start a new topic, rather than to dig up a 3 year old thread.
Thx.
Re: RCA Inputs...
Posted: Fri Jul 01, 2011 6:16 pm
by swampthing
wow when I saw it under "new posts" I didn't think to check the date
