Re: adding heated mirrors
Posted: Tue Jan 14, 2014 2:10 pm
Chances are the extra wires aren't there if the car didn't have the mirror upgrade from the factory. GM almost never included an inch of wiring they didn't absolutely have to.
The forum for Pontiac Bonneville enthusiasts
http://www.pontiacbonnevilleclub.com/forum/viewtopic.php?t=41492
You're correct. The wiring harness in my SE (non-heated power windows) is missing the positive lead for the heated mirrors.human wrote:Chances are the extra wires aren't there if the car didn't have the mirror upgrade from the factory. GM almost never included an inch of wiring they didn't absolutely have to.
It appears so. I wasn't able to trace the wire on the junkyard car back to see where it goes. The unused wire in my car's power mirror wiring harness is a ground. Do the two mirror defrost power wires (one on each side) run from the mirror directly to the back of the ECC? Shouldn't there be a relay in that circuit?95se wrote:so the wire its missing is the power wire from the defrost button?
