Re: Por-15
Posted: Tue Aug 14, 2012 11:06 pm
LOL, I put 90k miles onto that LeSabre in the roughly 3.5 years I had it. About evenly spaced each year, too. The Cruze will likely be just under 28k miles on its first birthday. Work sucks...
$300 will have you set up nicely in the rust-repair department. That's 2 new rocker panel skins, enough POR-15 to last a loooong time (didn't use a full quart, even applying it very liberally), painting supplies, safety equipment such as earplugs/respirator/gloves/goggles/disposable long-sleeve shirt, and some new tools like an angle grinder and cutoff/grinding wheels.
POR-15 is some seriously nasty stuff. It reeks to high heaven when open, and being in close proximity to it for extended periods of time without safety gear is highly discouraged. Make sure the respirator is organic vapor rated, since your head will be nearby where you're painting it for a long time. And, if it gets onto your hands, forget about getting it off for a week or so. I thought I was going overboard on with quantity and use of safety gear. It ended up being just enough, and used enough to keep some potentially serious injuries from happening.
The other benefit of geeking out in safety gear before working on the car was I could work on it far more comfortably, and wasn't distracted by fumes or sparks as much. Instead of getting sick on paint fumes or dust from grinding down rust, the respirator let me breathe pretty normally without being sick after painting or grinding. The gloves kept sparks/paint from my hands, and gave a better grip on tools than sweaty, filthy hands. Ditto the goggles for my eyes. More than a few pieces of rust were deflected away by the safety goggles.
Be safe. You can always replace panels or an entire car. You can't replace your health.
