Now getting a randon surging tach and then die at stop sign
Re: Now getting a randon surging tach and then die at stop s
A hogan DP that bolts right in the place of the stocker is $140 and is an excellent performance upgrade, otherwise haro probably has a stock one for $50 or so.
http://www.hoganperformance.com/DP8S.htm
- SSEiMan01
- Year and Trim: .
03 PAU - Location: DeKalb, IL
I still have mine If Haro doesn't have any...I'd just have to unbolt it from my cat...it has about 52k miles on it...
$35 plus shipping
James May wrote:Hello.
Mac077
- Posts like an LN3
- Year and Trim: 2000 SSEi & 2005 SE
Great, I will let Haro chime in but thanks for the info! Mine didn't look like it had a bubble in the middle though??
2000 SSEi (Silver Eagle) cleared corners (before accident) new LIM gasket, drilled 180 T-stat, new plugs and wires, new valve cover gaskets, new Supercharger gasket, third brake light overlay. Hopefully soon to start more mods for performance. Also, 2005 White SE totally stock and will remain that way!
Thank you Bob & Vince for your hard work and kindness!!
- Year and Trim: .
It is up close to the flange for the rear manifold.
Mac077
- Posts like an LN3
I believe so...the muffler guy was trying to figure out where it was coming from and that is what he thought. That is was up high towards where it connects to the manifold.
Mac077
- Posts like an LN3
Bump
- Year and Trim: .
The flex joint is right after the flange to the rear manifold. They can get a leak there. There is also a steel gasket at that flange. Might want to put an ad in the wanted area to get more attention.
What did they do to check the cat?
JEzze
- GXP Member
- Year and Trim: 2000 quicksilver SSEI
Curious is the Maf screen in the tb still?
DDM tuning HID 6000k hi/lows and fogz
FWI, 180*tstate / 18 inch enkie wraped with potenza run flats , danturs tuned pcm,
Home made motor mount / autolite 605plugs/beldin performance wires. Hogan 3 inch dp w/ magnaflow hiflo cat, zzp plot and 3.4 smoothflow MpS, trans go shift kit, 10 inch gtablet mounted running torque app.
I have a kr issue please help....
Mac077
- Posts like an LN3
To check they drilled a couple of holes and put some type of monitor or camera in it to check it then tacked it back closed.
Not quite sure about the MAF question...it is where it is suppose to be! And was just replaced a couple of months ago!
- Year and Trim: .
A few things to look at.
Pull the plugs and check the gaps and condition. Make sure all the plug wires are in good condition and not touching anything. Do you have any sort of scanner? I would like to see how the TPS (throttle position sensor) is acting. How about a spare ICM or coils?
Which plug wires are you running? If they are a set of cheap ones, you might want to replace them.
Also do the spray test at night. Get the car to where it is running like this and then spray a mist of water around the plug wires and ignition coils and look for an arc from the wires and coils.
The only things throwing me off is that it runs fine when cold. A warm issue leads to things like the crank sensor, ICM or cat. This is where a scanner would come in real handy to see some data.
Mac077
- Posts like an LN3
Unfortunately I do not have a scanner...really, really want one but no budget for it! I don't have spare coils or or ICM either. Will give it the spray test tonight. My gut tells me it is a fuel issue because it also runs really crappy when, from a stop, you just barely touch the gas, it misses and bucks until you give a little bit more gas!! Fuel filter possibly or could be my injectors are a but plugged. I don't use the best gas and should be using a fuel additive to help keep things cleaned up but I haven't. Hope this helps!!
Replace the fuel filter, it's a 20 minute job.
http://www.pontiacbonnevilleclub.com/fo ... 45&t=23215
