Page 2 of 5
Re: Supercharger Pulley.
Posted: Thu Feb 04, 2010 3:29 pm
by Sadden
Yes.
NO torsen for me. At least till i put a 65 on the bench.
Posted: Thu Feb 04, 2010 10:06 pm
by 01bonneSC
There are K&N prechargers, covers that go over the filter to aid in filtering.
Posted: Fri Feb 05, 2010 9:19 am
by willwren
There is one option for an LSD available, but the turnaround time is long, and I don't know if he's even making them any more. Haven't heard a peep in some time. Here's my install topic:
viewtopic.php?f=12&t=9823&hilit=lsd
It also requires modification of the output shaft.
Posted: Fri Feb 05, 2010 3:45 pm
by Sadden
Yeah thanks.
I think ill probably end up putting a SII and 4T65 Combo on the bench to spend some money on. This is just going to be to keep me happy till that happens and is completed. thanks for all the input guys. Over the next couple days ill get some pics up of the two superchargers i have. And then ill put the worse one on my car and send the better one off to someone who who would be willing to P&P it. And when it gets back ill Pulley down and Custom Fab a CAI.
Thanks for all the Input Everyone.
Posted: Fri Feb 05, 2010 5:28 pm
Why don't you put the better one on your car and send the worse one off and have it rebuilt and P&P'd? It needs to be almost completely torn apart to P&P it anyways.
Posted: Fri Feb 05, 2010 6:49 pm
by Sadden
Because i suspect they are two different gens. So ill send the one that has the most potential off to get worked and live with the not as good one for now.
Posted: Fri Feb 05, 2010 7:03 pm
by willwren
It's not that simple to interchange them.
Posted: Sat Feb 06, 2010 3:26 pm
by Sadden
What needs to be done? I thought the only real differences where a tweaked inlet and epoxy coated rotors?
Posted: Sat Feb 06, 2010 4:31 pm
by J Wikoff
The inlet is quite a bit bigger on the 94/95, and would cause quite a flow disruption if you used mismatched SC and TBs. If the ribbing on the SC is the same, tapering off about halfway down the case, you're fine.
Posted: Sun Feb 07, 2010 12:52 am
by Sadden
Oh Okay.
Yeah the ribbing does match up and does taper off. ( i cant rember which is which atm )
Ill put some pics up tommorow so you guys can confirm which is which.
Posted: Sun Feb 21, 2010 3:11 pm
by Sadden
Hey everyone sorry about the wait. Im uploading the pictures right now.
Posted: Sun Feb 21, 2010 8:33 pm
by Sadden
Trunk
On at the moment. (stock to my knowledge)
Posted: Sun Feb 21, 2010 9:33 pm
by willwren
You have the wrong supercharger on your car, and the one in your trunk doesn't look fit to compete until after a full rebuild.
Posted: Sun Feb 21, 2010 10:05 pm
by Sadden
What do you mean?
Whichever is better stock i will P&P.
Posted: Sun Feb 21, 2010 10:07 pm
by willwren
You have a 92/93 supercharger (Gen 2) on your car. I'd like to know if you also have the matching SMALLER throttle body. Does it have a thick plastic gasket between the TB and SC? And if so, which sensors? 94/95 MAF? Or 92/93 MAF?
Your car isn't running right, that's for sure.
Posted: Sun Feb 21, 2010 10:15 pm
by Sadden
How do i tell the difference between the MAF's
Posted: Sun Feb 21, 2010 10:24 pm
by Sadden
No thick gasket for sure.
Still unsure on the MAF.
Posted: Sun Feb 21, 2010 10:41 pm
Get the number of the MAF. That should tell us which one it is.
Posted: Sun Feb 21, 2010 10:44 pm
by willwren
Need the 7 or 8 digit part number off the TB too.
Posted: Sun Feb 21, 2010 10:59 pm
by Sadden
The MAF has 2 numbers on it. The MAF and TB appear to be a single unit. Heres what i got off the MAF.
AFH50M-03
s4112
