Hey hawkejet! Nice to see you here from you again. Yes, with the module you've listed you're absolutely correct. The one I had seen some time back was a plug-in replacement for the XM radio receiver which is why the BAND button was necessary. The software to control XM is in the head unit and only present in radios with the BAND button. The one you used IIRC is a replacement for a CDX and our head units were compatible with these all the way back to the 2000 MY so no head unit change would be needed.hawkjet wrote:Hello everyone,
I haven't been on this forum for some time. Hello Darcy - long time no talk! You were the major resource for me to get my system working. THANKS again!
lewis26 PMed me about this thread and I noticed some incorrect assumptions/information. I'll clarify this now:Sorry Darcy, this is not accurate. I don't have a band button and I just drove from Seattle to California while listening to my iPod.ddalder wrote:In order to achieve this you would need to swap your head unit to one with a "BAND" button instead of "AM/FM".
The main difference between the head units is mostly the nomenclature on the button. There is a difference in the radio's firmware because of the satelite radio option, but it seems to be in the radio and not something the Class 2 Serial Bus knows about.
Aux input on 00+ with Bose, Onstar & no cd changer .
ddalder
Re: Aux input on 00+ with Bose, Onstar & no cd changer .
- hawkjet
- Posts like an LG3
- Year and Trim: 2001 Bonneville SE
It will send the appropriate signal through the Class 2 Serial Bus to allow for an input that is different than the head unit. You can then have a selector switch if you want to choose from various additional inputs.Oldsman105 wrote:Does it also have a extra input for my satelitte radio or do I need to go a diffrent route?
2001 Bonneville SE - Dark Bronzemist Metallic - Mods: 180* thermostat, iPod adapter, Digital OnStar Upgrade
Planned Audio System upgrades: Front & Rear 7 Band Equalizer, Amps, Hands Free Bluetooth Cell Phone kit
Planned mods: Front PEM, Ported LIM, Ported Heads, ZZP SR Rockers, Aluminum Gaskets & Reprogram PCM
http://www.hawkjet.com
- Oldsman105
- Posts like a Northstar
Sweet!
Thank you all for your help!
lewis26
- Posts like an L27
- Year and Trim: 2003 SLE || 51k miles
Hawkjet, is there a similar device with RCA or 1/8" inputs instead of iPod. This might make more sense for Oldsman so that he can plug in whatever he wants into a headphone/line out port instead of proprietary iPod connector.
-Mike
- hawkjet
- Posts like an LG3
It is the same device but a different cable instead of the iPod cable. It is a simple matter to determine which pins are the audio input and splice into them. It's been long enough that I don't remember which pins, but I searched online and found the pinouts for the iPod docking connector....lewis26 wrote:Hawkjet, is there a similar device with RCA or 1/8" inputs instead of iPod.
