Well, I had a busy weekend. It seems like I didn't make as much progress as I wanted, but then again there was a lot to do..
Those trim pieces that had shattered took several layers of epoxy to fix them; good thing I was planning to wrap them from the beginning:
Crazy what 33 years will do to the color of the interior on a car:
After a bunch of work, I got the headliner and most of the trim installed (it was difficult to get a good picture, the camera flash messes with the colors):
Then once I got the amp wired up I moved on to the seats. The plan is to make a frame that I can bolt the seat tracks to. I wasn't about to tear up the original bench tracks to fit, and I'd need to get another set anyway. So I ended up cutting the tracks off their mounting brackets that came with the seats. Unfortunately, my grand plans to put the powered seat tracks in did not pan out, they were simply too tall.
I'm still debating if I should just weld the hacked up tracks directly to the frame I made. It would certainly make things a bit easier.
Other things I got done: Replaced the floppy hinge pins and bushings, re-hung the doors (will have to see how the drivers door lines up to the fender), finished wiring up the stereo and amp, re-installed the bottom of the dash, painted the kick panels as it doesn't make sense to wrap something that's going to be in contact with dirty shoes..
So next on the agenda is trying to find the matching seatbelt set from the GMT400. It looks like they will be a very close fit, if not 100% bolt on. The seat belts from the truck are a complete mess and not worth the hassle of trying to clean them up and the losing prospect of dyeing them to match; when GM already made a color matched set I can pull from a donor.
I bought 3 yards of the fabric to cover the interior, and I ran out before I could even get to the doors. I don't know how I could have done that, seems like when I measured it out before 3 should have done it. But it's not that expensive that I'm going to worry about it. I had to order more, so the door panels are coming off and staying off for a little while.
