Northstar Help
94SilverSSEi
Year and Trim: 97.2 40th SLE
68 w/400
94 SSEi
Northstar Help
Post by 94SilverSSEi »
Can anyone give me just the basics about a Northstar
Ive hearf they can be really good if taken care of and something about putting too much oil in
The car im looking at is a 98 DEville is that helps at all
Also I have heard that the intake or something about that leaks
I need some help looking at a car with 115k on the clock and am wondering how good these engines are
I have also heard to stay away from them unless they are under 100k but then there are the believers that they are very good strong engines
Please Help
Thanks
Clay
1997.2 40th SLE-138k
1999 GMC Suburban SLT-191k
2005 Escalade 253k-GINA
94SilverSSEi
68 w/400
94 SSEi
Re: Northstar Help
Bump......Anyone
Clay
blubyu
Year and Trim: 2004 GXP
Re: Northstar Help
Post by blubyu »
No issues with mine @ 95K miles.
CincyGXP
Year and Trim: 2004 Bonneville GXP
98 SE
Olds Aurora Final 500
Re: Northstar Help
Post by CincyGXP »
The Northstars are very reliable engines. I would make sure on your year (98) that the rear main seal has been resealed, if it's leaking. Other than that, these engines will last many miles.
2.3 turbocoupe
Re: Northstar Help
Post by 2.3 turbocoupe »
The main thing I am aware of is they are somewhat prone to headgasket failures. There was an improvement in the head bolts in 2003 I think. Some of the older ones had blocks that were porus and could leak oil, you might watch out for that as well, and should be easy to spot if it is present.
2005 GXP Silver, Gutted Airbox, K&N filter, 14.61 @ 94.31 mph.
1987 t-bird 2.3 turbo, stock motor with home-ported head, big turbo, big exhaust, alky injection, a bunch of other little stuff, 13.65 @ 102 on radials.
Jim W
Year and Trim: 1997 Oldsmobile Aurora
2008 Buick Enclave CXL
Re: Northstar Help
Post by Jim W »
Head bolt improvment was made in the 00, 01 MY
04 Pontiac Grand Prix GTP CompG
GXP Venom
Banned
Year and Trim: 05
Re: Northstar Help
Post by GXP Venom »
Yes, and the headbolts really haven't been an issue since, other than you dont want to severely overheat any all aluminum engine. But the tales live on :roll: 115,000 miles is a bit to a older northstar regardless. They are not a 3800. And the retail price of a 97 Caddy should reflect that. Any maintenance or repairs not done by yourself is expensive.
2.3 turbocoupe
Re: Northstar Help
Not sure what was changed in 00, 01, but I checked on it and they changed the headbolts in 2004. Went to a coarse thread (about 1/2 the threadcount). Not sure if that change helped any, but the bolts are quite different. Either way, a 98 Northstar engine was prior to either of those changes and they have more than their share of HG failures, even the ones that are babied.
GXP Venom
Banned
Year and Trim: 05
Re: Northstar Help
Post by GXP Venom »
Ya, I did a writeup about it long ago in another Forum, and cant remember the year, but it was well after '97. "Squeeze cast" technology also hardened the block so the tapped holes are stronger, but that wasnt that long ago either.
