Strange DIC reading...
skypilot
Year and Trim: 01 SSEi
96SE
Post by skypilot »
Does anyone know what a Service Stabilization System message in the DIC means? :helpsmilie:
ChildOfGod Motorsports..."burn rubber not your soul."
"May The GOOD LORD Bless You Where The Rubber Meets The Road"
Bonneville Pro COTM JUNE 2008
Re: Strange DIC reading...
All to common message in the 2000+. Its common that you either have a problem with a WSS (wheel speed sensor), steering wheel position sensor or some wiring near the WSS. The problem can only be diagnosed with a Tech2 or similar.
skypilot
96SE
Post by skypilot »
Thanks Haro,
Just one more question, so far no other lights are on, how does this effect drivability?
Are your TRAC OFF and ABS lights on? If so, you no longer have either of the 2. If those lights aren't on, I think the only thing you might lose is the Stabilitrack.
skypilot
96SE
Post by skypilot »
So far no other lights off or on. Now I have to look up Stabilitrack and find out what that is....thanks
Archon
Post by Archon »
The Stabilitrak system is what activates when your car starts to go into a slide on a turn. If a wheel speed sensor is bad, that will generally also turn on the traction control and abs off lights. The most common problem for the service stability system is a bad steering position sensor. If work has been done on the intermediate steering shaft, and the steering wheel is not held in position, it can cause problems with that sensor.
Haro is right in that the abs and traction control should work OK.
white06lacrossecxs
Year and Trim: 2006 Buick Lacrosse CXS
Post by white06lacrossecxs »
Its a PITA to replace the SWPS. The part is only $78 but the labor is about $275. Main reason being is that the column needs to be removed from the vehicle. (At least on the Park Ave.) I just figured I would live with it.
Removing the column is not that hard of a job. Yes, the shops will charge you $275 in labor, but you can easily do it yourself.
