Headers Come Tommorrow!!!
The Crunge II
Year and Trim: 1996 SE
Post by The Crunge II »
I need Header wrap to prevent the headers from frying my 4T60.
Can you buy this at a local store or is this a specialty online only item?
1996 SE w/ magnaflow high flow cat, 180* Drilled T-Stat, intense FWI, PLIM, ER Rockers w/stock springs, 1 5/8ths primary pacesetter headers
wingman
Re: Headers Come Tommorrow!!!
Post by wingman »
oh yeah.....you can buy header wrap at stores like autozone, advanced auto parts, etc.
good luck with the install!
CAI - PEMs - ZZP 2.5" DP - PLIM - 180* T-stat - AL605s - 245/50R16 - cleared front & rear corners - 20% tint - GXP strut brace
danthurs
Year and Trim: 1997 Bonneville SSEi
Post by danthurs »
IMO only wrap what you need to to shield the trans. Wrap tends to hold in moisture and will start to rust the welds.
Mods, CAI, Gatorback SC belt, 180 deg. thermostat, sparkplugs 2 colder gapped @ .050, 3.1" MPS, intense™ PCM, AeroForce scan gauge, Flowmaster series 80 muffler, 3" Magnaflow cat , INTENSE™ Street/Strip Performance Shift Pak, 1.9:1 roller rockers, Oil Restricted pushrods, CompCam #105 springs, CompCam heavy duty spring retainers and valve locks, 17" wheels, 245/45 FirehawkGT tires,slotted rotors, cermaic pads, Wideband O2, MSD Blaster coils, MSD 8.5mm sparkplug wires, Stainless steel TOG headers, HP tuner, P&P LIM and supercharger, SSIC
Getting ready to install cowled hood, Project on hold!
Objects in mirror are loosing!
2003 SSEi
Year and Trim: 2003 SSEi.
LOTS of Mods
Post by 2003 SSEi »
i wouldnt wrap them
2000Silverbullet
Post by 2000Silverbullet »
Only wrap the crossover from the front to the rear where it goes over the trani. It should stay dry up there.
If you get any salt spray on them and they are wrapped, they will corrode very quickly.
1994se
Post by 1994se »
I wrapped my PEMS in that way and my SLP's are wrapped there as well. I didn't have any problems with the crossover on the PEM being wrapped for 2 years so i'm not too worried.
http://www.thechicagogarage.org - Now Home of ILGPC
dirtracr95
Year and Trim: 1988 and 1987 Buick Lesabre T-Type
Post by dirtracr95 »
1994se wrote:I wrapped my PEMS in that way and my SLP's are wrapped there as well. I didn't have any problems with the crossover on the PEM being wrapped for 2 years so i'm not too worried.
and thats in IL salt!
~~~Freddy~~~ Wyotech Graduate, Future RCSAMS student
Pandora 1988 Lesabre T-Type 259000 miles
Darlington 1987 Lesabre T-Type 115000 miles
Cream Puff 1988 Lesabre T-Type 194500 miles
1994se
Post by 1994se »
But only the middle of the crossover, not on the welds.
BillBoost37
Year and Trim: 00 Regal
Post by BillBoost37 »
Take some close looks at what Oldsman did to try and shield his and how he redid his connector.
I hope you can get them to clear the connector enough.
97 Ei
97 GS
98 GS
The Crunge II
Well even after grinding down the front motor mount to barely nothing the headers still wont clear it :sad:, i'm about to give up and put them up for sale...
BillBoost37
Don't give up. Get even with it and make it strong at the same time. There are two 96-99's running these and a couple other alternatives out there as well.
This one looks closer than it is because of the angle.
Been on my car for over a year and it hasn't torn or shown any signs of having any issues. Plus it firmed up the front w/o any added vibration.
97 Ei
97 GS
98 GS
PDXGTP
Year and Trim: 1998 Pontiac Grand Prix GTP
Post by PDXGTP »
The Crunge II wrote:Well even after grinding down the front motor mount to barely nothing the headers still wont clear it :sad:, i'm about to give up and put them up for sale...
If all else fails I'd install the headers and not install the bracket until you have a replacement bracket that has been modified. Your bracket is likely broken anyway.
There are too many options on how to remedy that situation.. Never give up.
On Bob's car we just cut off the part that connected the shock thingy, that's only half the bracket anyway, then after we clearanced the headers we found a chunk of metal with the right angle (90* bend) and we welded it in place then ran a bolt thru it with rubber end-link bushings just like in the photo that boosty posted.
Never give up.
Always continue forward, its just a puzzle, figure it out, make it fun and engineer it until it becomes a personal victory.
Best 60' = 1.716
Best ET = 12.186
Best MPH = 112.98
danthurs
Post by danthurs »
I had to remove a lot on mine. These are TOGs but should be some what close.
The Crunge II
well the shocky part is the only part in the way anyway... you think i can get along with out it?
danthurs
Post by danthurs »
I had that one part off for a while and didn't know it. All I noticed was some rough shifts at low speeds. It's just a shock absorber. The mount is under it.
olblueeyesbonne
Year and Trim: 99 SSEi
01 SLE
02 GTP40th
02 SSEi
06 GP GT
Post by olblueeyesbonne »
If it's not too late -use dynamat on the top of the trans, directly below the crossover instead of wrapping the header crossover and risking damage to the pricey headers.
DHP Powrtuner & Tech 2
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
2002 GTP 40th Anniv Ed Coupe
The Crunge II
ill look into dynamat... never heard of it before, but the flange on the header is really close to the wire harness on the trans so idk if itll fit...
olblueeyesbonne
01 SLE
02 GTP40th
02 SSEi
06 GP GT
Might look into going to Home Depot/Menards for Reflectex. That'd be another option -don't know how it'd handle the heat of the headers from less than an inch.
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
The Crunge II
Well i took the shock bracket off and got the front header on, but it is touching the wireharness on the trans so there is nothing else i can do...
danthurs
Post by danthurs »
Not really the best option in the world, but what about denting the crossover pipe in a bit near the wires to get it away from it. Better yet, if you have a muffler shop that is willing to help out, have them bend it a bit, or cut and weld in a new piece making a custom crossover pipe. May cost a bit but better then damaging the wires/trans. Or removing the headers completely.
