What can be used to remove VHT? I have a set of tail lights that are wayyy to dark (cant see them at all during the day basically)
Going to respray them - How many coats?
Remove VHT
Re: Remove VHT
I haven't had to remove it from the tails, but I have from the 3rd brake light project. We had 2 coats of vht and 2 coats of clear and it took a lot of rubbin with 400 grit to remove it and then some 1000 grit before respraying. I don't know what to do for something as large as the tails.
EWC88
- Year and Trim: 01 Se
Re: Remove VHT
I forget who it was who said it on Pontiac Bonneville Club (might of been old forum but I know there still apart) they got a hand sander for like 14 bucks and use hand sanitzer and it worked. I haven't tried it yet but been needing to cause mine are pretty dark as well and like to do a new 3 coats and clear then wax/polish them.
R.I.P 2001 Se :(
Plurr
- Posts like an L36
- Year and Trim: 1994 SSE
Re: Remove VHT
I used laquer thinner on a set of tails on a 300 that needed to have it stripped, you can sand down a bit if you want but make sure you don't choose too rough of a grit because it will end up scratching the tails if you are not careful. Laquer thinner and some rubbing with lots of paper towels made them look like they never had any vht on them.
1994 SSE, 180 t-stat, gucci accented interior, suede headliner, eclipse avx5000 headunit, two 7.8" sunvisor screens, two 7" headrest screens, dvd player / tv tuner, infinity kappa perfect 5.1 components, infinity 12.1 perfect in the trunk, 2 rockford fosgate 350s powers, infinity refrence 7541a, 0 gauge audiobahn high flow wiring, duralast gold battery, sound dampened trunk and doors, xenon-white headlights, 2 15" and 1 20" red neons shine on the back doors, 2 3" and 6 12" blacklights lighting up the whole interior, red leds in the vents, red optx el neon pedals, red streetglow headlight leds, clear corners, pilot seven color angel eyes, blaze seven color underlighting kit, viper 791 xv.
