a few questions
agape1983
Year and Trim: 93 ssei
a few questions
Post by agape1983 »
i have a 93 ssei and i need to know where my ecu is located and what jet stage 2 chip i get(Bonneville is not listed) and also i want to do a rear disc conversion. how do i make my supercharger whine louder
Andrew88
Year and Trim: 1993 Lumina sedan
Re: a few questions
Post by Andrew88 »
-Andrew
alexcoqui
Year and Trim: 2001 Blue SLE - 2001 Black SSEI - 2005 Grey Aztek
Re: a few questions
Post by alexcoqui »
I dont think there is a chip for the Bonnevilles, there is no company that makes a disc conversion kit. & if you want to hear more of the wine, then you need one of these: http://intense-racing.com/Merchant2/mer ... _Induction
2001 Blue SLE - 1995 Black SSE - 1988 Black GTA
Re: a few questions
Andrew88 wrote:get a hearing aid?
Please post in the mechanical sections only if you are truely helping.
The ECU on these cars is typically called the PCM. It is located up under passenger side footwell. There are 3 large connectors, red white and blue. Once you get the PCM out of the car, there are 2 screw you remove to gain access to the EPROM chip inside the PCM, which is actually what you change out.
The part number for the Computer Chip | Stage 2 | Auto Transmission is 19303S. I easily found it on jetchip.com.
Nobody has ever done a rear disc swap yet, but there is talk of it: http://www.pontiacbonnevilleclub.com/fo ... =12&t=5905
agape1983
Re: a few questions
Post by agape1983 »
thank you harofreak for the info i asked for
