Grinding Grizz!
- willwren
- Retired Admin
Re: Grinding Grizz!
Ok, which is it?
Knock sensor, or ESC circuit? They're not related at all.
- 2000Silverbullet
- Retired Gearhead
Re: Grinding Grizz!
Well the scanner says 325 Elec Spark Control failure but when I look in the FSM it relates 325 to the Knock sensor circuit.
- 2000Silverbullet
- Retired Gearhead
Re: Grinding Grizz!
The SES code has been removed.
The Knock sensor connector had somehow come off.
The noise was isolated to the torque axis mount. I can lever a screw driver to make the engine move forwards and backwards at the passenger side and the forks of the engine bracket mount contact the metal wrapped rubber piece.
Now, I need some help to determine if this torque axis mount is supposed to control that kind of movement.......or is it the lower transaxle dogbone??
GM service said it was the torque axis mount that needs to be replaced........but it's $200. !!!!
The dogbone is only $30. but the closes one is in Ontario.
Bill - can you try to pry yours back and forth to see if you get movement?
- JMH1950
- Posts like an L36
- Year and Trim: no longer a Bonneville owner
Re: Grinding Grizz!
Bill has a spare of everything. Now it may cost you to get it up here, but he probably has one.
2001 F150 a basic six cyl with 5 speed manual trans.wjcollier07 wrote:Darn it John...now you got me thinking mine's not big enough.
'66 Piper Cherokee 360 CID , 180 hp, 155 mph @ 2500 rpm, drop in K&N filter.
BillBoost37
- Year and Trim: 00 Regal
Re: Grinding Grizz!
BillBoost37 wrote:LOL, I know what is probably causing that noise.
The engine mount.
2000Silverbullet wrote:The noise was isolated to the torque axis mount. I can lever a screw driver to make the engine move forwards and backwards at the passenger side and the forks of the engine bracket mount contact the metal wrapped rubber piece.
97 Ei
97 GS
98 GS
97 GS
98 GS
- 2000Silverbullet
- Retired Gearhead
Re: Grinding Grizz!
But is this torque axis mount supposed to absorb side to side movement or is it the torque mount dogbone??I need some help to determine if this torque axis mount is supposed to control that kind of movement.......or is it the lower transaxle dogbone??
The rubber looks new and the metal ring is not moving relative to the outer shell.
I don't want to spend money on the more expensive mount, if the cheaper one is the one at fault.
- willwren
- Retired Admin
Re: Grinding Grizz!
Boosty is right and wrong. The TA mount is not COMMON. It's the second-least likely to fail. It is also, however, oil filled and designed to dampen motion.
The dogbone is the least of your worries. The rubber bushing portion allows very little motion and rarely, if ever fails.
Most common in order:
1. Front trans mount, driver's side.
2. Rear trans mount, driver's side.
3. TA mount (way down the list of odds compared to #1 or #2)
4. Dogbone.
This is true for 92-99 H bodies.
In all my time on this Forum, the previous forum, over 10000 members of this club, and all the cars I've personally wrenched, I KNOW of only ONE confirmed failed TA mount. Grizz would be #2, but the Zilla was close (but in a different league due to the abuse). I certainly wouldn't call this common or quite common. And yes, I read EVERY 92-99 topic posted. While it may be the problem in this case, I think it's important not to over-state the possibilities or failure rates, as new members may be prone to shotgunning problems based on this.
The TA mount serves the following purposes in life:
1. Controls TORQUE AXIS motion when accellerating or deccellerating.
2. Helps dampen vibrations due to the oil-filled rubber-housed cavity.
3. Supports the engine (engine only, not trans) on the passenger side.
There is LIMITED control of motion from wheel to wheel along the crank axis, and rotational motion on a 'street plane' about the center of the engine.
4. Dogbone.
- 99ssei
- Posts like an L27
Re: Grinding Grizz!
Just to add my .02...With 144K, I'm on my third (3) trans/motor mount (Currently running a Boostie special! - Thanks again!) and third (3) side motor mount, and just replaced my dogbone mount for the first time (never replaced the rear trans mount - still looks great!). The dogbone was replaced because it was very loose (could wiggle it around with pry bar).
As stated earlier - rockauto is the way to go.
Re: Grinding Grizz!
If you have any questions on the RockAuto catalog, you can contact us directly: service@rockauto.com or 866-ROCKAUTO. You can also catch me here
www.rockauto.com
Thanks!
Ashley
www.rockauto.com
Thanks!
Ashley
- 2000Silverbullet
- Retired Gearhead
Re: Grinding Grizz!
That kind of life from a $250. motor mount is totally unacceptable!With 144K, I'm on my third (3) trans/motor mount (Currently running a Boostie special! - Thanks again!) and third (3) side motor mount, and just replaced my dogbone mount for the first time (never replaced the rear trans mount - still looks great!). The dogbone was replaced because it was very loose (could wiggle it around with pry bar).
If that's the kind of life to expect from the mounts.....it's time to get rid of this POS!
I think that the Grizz will just grind for quite a while........until something falls off.....
I refuse to keep shotgunning money at this POS!
- willwren
- Retired Admin
Re: Grinding Grizz!
Paul, read my post. It's quite uncommon to have that mount go. I suspect he had other issues, like another mount allowing too much motion, or substandard (poor quality) parts.
I bought mine from Rock Auto as well. All the mounts currently on the Zilla, actually.
If that mount is your problem, replace it. But CAREFULLY check the others. One other bad mount will increase the load on all the others and shorten their life as well.
- 2000Silverbullet
- Retired Gearhead
Re: Grinding Grizz!
Bill, I really don't know if that mount is the problem.
That's the issue.
I've had mechanics look at it and tell me that is the problem because they can see the mount hitting but........they don't know if it's the other mounts causing this one to hyperextend in the wrong direction of its axis.
Can you pry your mount over using a crowbar so it contacts the forks?
If you can't, then it could be the torque dogbone or even the rear trani mount that is allowing it.
We are having difficulty prioritizing the repairs.
Victor has limited funds.
He can't even afford to pay for his $300. computer repairs.......and I'm done funding his mistakes.
That's the issue.
- willwren
- Retired Admin
Re: Grinding Grizz!
Paul, it's cheap (free) and easy to ramp the car in the garage and use a jack to test all the mounts. If iron meets steel on the two halves of that mount, either that mount or another is allowing it. There are only 4 to check.
BillBoost37
Re: Grinding Grizz!
Not looking to step on toes or disprove anyone. Please take this as constructive and helpful only.
I have seem 6-10 of the TA mounts go bad on various vehicles. My own personal mount is shot after only 20K on a fresh mount. Other respected folks on this forum have mentioned their mount being replaced many times as well. The TA mount is the only mount absorbing the desire of the motor to torque on the passenger side of the vehicle. When it is bad the engine side bracket can hit the body side bracket, metal on metal transfers some engine vibration to the body. Currently my mount is in need of replacement.
Paul, here in the states that front mount is $45 from Rockauto, the rear trans mount $11, and the TA mount is $45. Those are not discounted prices. It's unfortunate that you live in Canada when it comes to prices on parts.
If I were to rank my experiences with mounts failing on the 92-99 B'villes it would look like this:
2. TA mount
3. Rear trans mount
4. Dogbone mount.
2. TA mount
3. Rear trans mount
4. Dogbone mount.
97 Ei
97 GS
98 GS
97 GS
98 GS
- 99ssei
- Posts like an L27
Re: Grinding Grizz!
X 2BillBoost37 wrote:Not looking to step on toes or disprove anyone. Please take this as constructive and helpful only.
2. TA mount
3. Rear trans mount
4. Dogbone mount.
- 2000Silverbullet
- Retired Gearhead
Re: Grinding Grizz!
x2Paul, here in the states that front mount is $45 from Rockauto, the rear trans mount $11, and the TA mount is $45. Those are not discounted prices. It's unfortunate that you live in Canada when it comes to prices on parts.
How can this be? Even with exchange and freight costs.....
$45 to $250 is either robbery or else the Rockauto part is substandard and that might explain why you go thru so many of them so quickly.
......or it's a design flaw that causes premature failure.
Either way, the Grizz is going to live with the Grinding for a while....
- 99ssei
- Posts like an L27
Re: Grinding Grizz!
Trans mounts for the 2000 at Rock Auto:2000Silverbullet wrote:How can this be? Even with exchange and freight costs.....![]()
Motor mount through GM parts direct:
I think it's the latter. A project I will start soon is removing the rubber from the side motor mount and insert some hockey pucks.2000Silverbullet wrote:$45 to $250 is either robbery or else the Rockauto part is substandard and that might explain why you go thru so many of them so quickly.
- J Wikoff
- Year and Trim: 1992 SSE
Re: Grinding Grizz!
Got a comparison of the mount the Grizz would use?
- 99ssei
- Posts like an L27
Re: Grinding Grizz!
Oh...I thought the 2000 was the Grizz. My mistake.
- J Wikoff
Re: Grinding Grizz!
It's a Series I. I had to go back too and saw it wasn't in the original post.
