here you go boys! Extractors a la Canadian! Special credits to Bill for the fantastic tech write-ups that make this easier for us new guys!
Working still on a stripe package....baby steps...
Plastic...but strong. From a mid 1980`s Trans Am. Their place was on the nose. These are rotated 90 degrees. Sanded, spot putty, primed, painted to code...3 coats of compatable clear. wilwren has done a great write-up at our old house...but we can`t link you....so you`ll have to search for it there. Good luck, I`ll think they`ll look good. Remember...measure TWICE...cut once..`cause there`s no going back once the sparks fly! A few beers for courage don`t hurt either....
I still need to finish mine. Brad drilled 5 holes in my hood in October and filled one back in. Havn't gotten to finishing it due to alot of other stuff going on. But in the next week or two I should have that and a few other projects done.
However, I don't see the TechInfo write up for the vents, it doesn't look like it made it over. I'll let everything settle in before I bother Wren about it, no rush anyway, still waiting on the engine
Ummm....let`s see...
$10 Us + ship ($10) E-Bay for vents = 20
$9.99 Cdn ea for paint (paint & Clear) = 20
Putty, wet-sandpaper I had at home (800grt,1000grt) free
You could do it all under 50$...depends how much you pay for the vents!
Oh yeah....my labour......$1500.00 per hour.....(why not? I`m worth it!)
I have no idea how much one would charge you...but they better be precise!
I took less than a day myself, start to finish.... taking it easy.
chopper442 wrote:Plastic...but strong. From a mid 1980`s Trans Am. Their place was on the nose. These are rotated 90 degrees. Sanded, spot putty, primed, painted to code...3 coats of compatable clear. wilwren has done a great write-up at our old house...but we can`t link you....so you`ll have to search for it there. Good luck, I`ll think they`ll look good. Remember...measure TWICE...cut once..`cause there`s no going back once the sparks fly! A few beers for courage don`t hurt either....
Peterg22000 wrote:I have my vent project started, but since I have to epaint my hood anyway, I'm doing mine a little different
do me a favour, and you get my the measurements of the outside edge of the vents to the outside edge of the hood (sides and back)
Ditto on that. Thanks. Looks good, man, no wait, looks great!
"Black Beauty"
So I ask him, what would the right price be? He tells me about six grand. I shouted back Are you serious??? Nobody would pay that!!! With an old man evil grin, he smiles and says, I know.
1994 Black SSEi, fully loaded, best $400 car I have ever owned;
1990 Ford Taurus SHO, currently needing a motor transplant :(
willwren wrote:The first set went on the Zilla. Second was Gravenge for driverjohn2005.
Trust me on this, after doing two sets. Measure from the CENTER HOOD CREASE, not the outside edge.
Looking GREAT.
ok, give me the measurement, from the center crease to the OUTSIDE edge on the vent (on its inside) Remember, I'm making the hole in the hood the same size as the vent itself.
2009 Phantom Metallic G8 GTS Appearance; Custom Engine Cover | HSV GTS Spoiler | GXP Front bumper | GXP rear diffuser | HSV GTS Triple Gauges with Dash/Console conversion(First in North America) | HSV GTS Sport Steering Wheel | 20% tint | Holden 6.0 Litre V8 Badges | VE Chrome Lugnut Caps | Blacked out Window & Grill Chrome | V6 door handles | Tinted Tails/Front Side Markers Performance; Roto Fab CAI | SLP PowerFlow axlebacks | X-Pipe(mid muffler/resignator delete) Handling; XA Coilovers
Sorry it took some time getting back...working nights! Bill`s right..... with the measurements...I would measure from the center crease of the hood. It was 9" center to edge of cut. Be aware that this will give you a hole in the hood that is smaller than the vent itself. The trim edge of the vent sits on top of the hood(and allows for a small amount of adjustment). You only have 1/25" or so of trim edge to cover hole so better to go smaller than bigger. I believe the vents come off the winshield cowl edge 7". You had better get the exact measurements from willwren to be sure...trust me...you do not want to make a mistake in cutting these holes! If you are planning to put these vents somewhere different, I don`t think I can help you much...but be advised , the area these are installed, is the flatest and most functional (braces underneath) you will find. Anywhere else and you will probable run into structure braces and hood contour problems. Good luck. PM if I can help any further. Maybe Bill can send you his write-up... it`s almost a must have for reference!
ok then....see you`re mounting them flush with the hood...like on the GTA.
Measured on the passenger side vent....
From edge of hood to edge of vent....13 1/2"
from center of hood (crease) to inboard edge of vent ....8 5/8"
from cowl to back right corner(from inside car, looking out) .....6"
from cowl to back left( in board corner) ....6 3/8"
these are as exact as I can make them...good luck, keep us posted!
