Seat removal when power not available...
Erinyes
Post by Erinyes »
Ran into this when stripping my 2001 - after gutting the engine compartment, I started on the interior, then realized I had stupidly left the front seats in the rearward position, blocking that one bolt. What to do?
Since it was a do-or-die scenario, I opened the factory repair manual and found the schematics for the seats. Turns out the motor that runs the horizontal control is positioned so that the 2-wire power connector is barely accessible, and applying power to one wire and ground to the other will rotate the motor.
Power to the tan wire moves the seat forward, power to the green wire moves it backward. Used jumper wires, a switch, and a fuse hooked up to a battery.
The only hitch is getting the connections tight enough to not pull excessive amps. I finally got one seat to move just by inserting spade terminals into the back of the connector, but the other seat I could not get a tight enough connection, and had issues with the jumper wires I was using turning red-hot. Blew a 40-amp fuse, too.
I finally clipped the wire connector off of the first seat motor, spliced my jumpers to that, plugged the connector into the socket under the seat, and it worked like a charm. Once I had the wiring setup rigged up, it was fairly easy (although a bit painful - the working area is tight!) to plug in the connector.
samples08
88,000k
Re: Seat removal when power not available...
Post by samples08 »
Next time try a drill battery they work wonders and will normally fit in tight spaces under the seat. But good work.
Member #3848
Erinyes
Post by Erinyes »
Tried a drill battery first, but most likely didn't have a tight connection at the motor connector - not a hint of motor action. Thought at the time that since the seat had a 30 amp fuse, the 1.5 amp battery just didn't have enough oomph to turn it. Just kept working through iterations until I had a setup that did the trick.
Good thing, too. The replacement car has a bad sunroof, and the headliner is drooping in multiple places - it's actually stapled into place at the rear window. The crunched car's headliner and sunroof are in excellent shape. I really wanted those seats out of the way to get parts out...
I simply apply 12v to orange wires and ground to black at the main connector. Why make it more difficult?
Erinyes
Post by Erinyes »
Well, we're all learning something new each day. Here's a post I found while scrambling around to find a solution...
http://www.pontiacbonnevilleclub.com/fo ... or#p439862
