Coolant In Engine Oil, Gaskets New?
20SSEi00
Year and Trim: 00 Bonneville SSEi
Post by 20SSEi00 »
Just had my L67 engine rebuilt and put back in my 2000 SSEI. I filled the engine with 5W-30 engine oil and coolant, now I’m losing a full radiators worth of coolant in about an hour. Refilling the radiator gets me a slow steady drip of water out from my oil pan drain bolt. I’m lost. Timing cover and lower intake manifold gaskets are new. My coolant elbows are metal ones and not leaking. Where else could I be loosing coolant into my crankcase? Any bolts or bolt holes I should be checking? I did use pipe thread sealant on my timing cover bolts. Any help would be appreciated and thanks in advance.
00 Bonneville SSEi
03 ZO6 - FAST 102 LSXR, LS2 TB, afe CAI, LTs, Catless X, Corsas
06 Cobalt SS LSJ
02 RSX Type S
02 Avalanche 8.1L Beast
20SSEi00
Re: Coolant In Engine Oil, Gaskets New?
Post by 20SSEi00 »
Well, found the leak. Timing cover and LIM gaskets were good. My rear main cover gasket was leaking. Seems the guy who rebuilt my engine didn’t scrap off all of the old gasket material when he put on the new gasket. Engine is back in and running, no leaks.
You can see the milkshake and indent on the new gasket being pressed over the old one.
Old gasket material still on rear main surface.
00 Bonneville SSEi
06 Cobalt SS LSJ
02 RSX Type S
Erinyes
Post by Erinyes »
Thanks for the follow-up. I was scratching my head, but had nothing useful to offer...
20SSEi00
Post by 20SSEi00 »
Erinyes wrote:Thanks for the follow-up. I was scratching my head, but had nothing useful to offer...
I’m just glad it wasn’t a cracked block. I’ll gladly take out the engine to change a $10 gasket over getting a short block fit $2000+
00 Bonneville SSEi
06 Cobalt SS LSJ
02 RSX Type S
The same guy who "rebuilt" the engine didn't scrap gasket material off the block before installing a new gasket? #-o I wouldn't count on that rebuilt for any amount of time...
20SSEi00
Post by 20SSEi00 »
harofreak00 wrote:The same guy who "rebuilt" the engine didn't scrap gasket material off the block before installing a new gasket? #-o I wouldn't count on that rebuilt for any amount of time...
Bruh. I hear you, and now I have a backfiring issue that I didn’t have before. Guess that means I’m gonna have to make another thread...
00 Bonneville SSEi
06 Cobalt SS LSJ
02 RSX Type S
dougtoth
Year and Trim: 2005SLE CRIMSON
2005SLE PEARL
1975 MONTE CARLO
Post by dougtoth »
After seeing the gasket fiasco I would make sure the spark plug wires are not crossed.
I would start there first.
95naSTA
Post by 95naSTA »
Sucks you had to pull it but at least you found it.
