Ignition issue
irish91983
1992 Bonneville SSEi (Sold)
Ignition issue
Post by irish91983 »
Hi all
Is or has anyone used the zzp high voltage coils and 10.5mm wires? I'm asking cause I'm currently using them with ngk laser iridium itr6f13. Since install I'm having a " big down" randomly through all rpms even at idle. Ran it with the plugs gapped at the .052 then gapped them to the .060 the car calls for with no change. Checked the firing order a million times. Has anyone run into this before? Or maybe the wires/coils are to much?
2001 SSEi Bumbles
Angel Eyes ~ Cleared Corners ~ Tinted Tails ~ Intense FWI ~ 20% Tint ~ 180 Drilled T-Stat ~ GXP Brake & Suspension Upgrade ~ Alternator Rewire ~ Intense Shift Kit ~ Headers ~ Tr 6's
Fan over ride~NGK Tr 55's~180 Drilled t-stat~Clear Corners~Angel Eyes~Tinted Tails~Magnaflow Cat
Re: Ignition issue
Do you have stock items to swap on as a test?
Namrepus28
Year and Trim: 2003 SSEi
Re: Ignition issue
Post by Namrepus28 »
Based on my experience with those exact products, one of your coil packs is shot. I had mine on for less than a year before one of them went south on me. Very disappointing.
Swap out with a stock one until you isolate which one so you can verify the cause. Then throw away the zzp coil packs and replace them with stock. Lol.
Their wires hold up just fine, no issues, but check to make sure they haven't been touching anything too hot and gotten burnt through.
2003 Pontiac Bonneville SSEi (L67) - Galaxy Silver Metallic
1996 Chevrolet Camaro (L36) - Sebring Silver
irish91983
Re: Ignition issue
I don't have any other stock parts left. Coils were cracked. I put in a brand new ICM and it made it worse to the point could barely go up a hill. I swapped my old one back in. Checked everything all over again. I'm gonna swing by NAPA and see if they will warranty my old wires. Also I have only been using the zzp plugs and wires for maybe about 2 weeks now has been happening since day one.
2001 SSEi Bumbles
dougtoth
Year and Trim: 2005SLE CRIMSON
2005SLE PEARL
1975 MONTE CARLO
Re: Ignition issue
Post by dougtoth »
Is there a junk yard near you where you can take off the whole ICM assembly with the coils on it?
Any 3800 starting with the year 2000 and up should work.
If not contact Andrew at Bonnevilles Unlimited (507) 220-2000 and he should be able to help you.
96 SSEi
Re: Ignition issue
Post by 96 SSEi »
you should pull the code and maybe it will pinpoint the cylinder# - then you trace to coil....wire, plug
the cheap oem coils are about 30 bucks. get one for spare /diagnosis if needed
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
irish91983
Re: Ignition issue
I did try that but no luck. No codes no misfires. Drove it with the tech 2 trying to isolate what cylinder but all day looked good. Gonna need to drive with a co pilot to verify.
2001 SSEi Bumbles
dougtoth
2005SLE PEARL
1975 MONTE CARLO
Re: Ignition issue
Post by dougtoth »
For what it is worth the last time my ICM went bad the SES light never came on and it did not throw a code.
I really think you have an ICM issue.
The new ICM'S are all Chinese garbage.
Try and get an OEM one from a junkyard or from Andrew.
