Guess this leak...Oil Pressure Sending Sensor?
Ramcharger310
Year and Trim: 01 Bonneville SSEi
Post by Ramcharger310 »
It is above the passenger side cv axle and below the power steering reservoir. I can't find the source.
2001 SSEi.
95naSTA
Re: Guess this leak...
Post by 95naSTA »
I would suggest power steering hose or axle seal. There's not much else back there.
Ramcharger310
I checked the hose coming out of the power steering reservoir. It is wet, but not dripping wet like this other part...
PS
Some sort of sensor that is super wet/leaking:
RJolly87
1994 Buick Regal Custom
Post by RJolly87 »
Probably the oil pressure sender, which is a known painpoint in these cars.
~Randall~
Ramcharger310
RJolly87 wrote:Probably the oil pressure sender, which is a known painpoint in these cars.
That's what I am thinking it is. Is this a simple remove old sensor and replace with new sensor deal?
The part seems cheap enough to DIY: https://www.partsgeek.com/1plxb66-ponti ... ender.html
peter
Year and Trim: 01 SSEI (black)
00 SSEI (green)
Post by peter »
Very easy to do.
Would suggest doing along with an oil change. If you remove the sensor prior to draining oil, it will lose oil thru that port. Not a big deal but easier to do with the oil drained regardless.
Re: Guess this leak...Oil Pressure Sending Sensor?
Very easy swap and you can get these parts at any local store.
Doing it with an oil change is recommend as without the oil filter, the access is a little easier.
dougtoth
Year and Trim: 2005SLE CRIMSON
2005SLE PEARL
1975 MONTE CARLO
Post by dougtoth »
Like stated above a pretty easy job with the oil filter off.
I bought a 27mm deep socket which made the job a lot easier.
Usually that sending unit goes bad and the oil pressure gauge reads all over.
Yeah, that's another good point. The socket size is huge at 27mm. Lol I was able to use an adjustable wrench the now 2 times I've had to replace mine.
Ramcharger310
27mm? Sounds like a good excuse to buy a new socket...https://smile.amazon.com/ARES-Retention ... B073WJ47R1
Also, should I go Duralast (cheaper & lifetime warranty) https://www.autozone.com/external-engin ... 862_0_1489
Or ACDelco (1yr warranty,but maybe better quality?) https://www.autozone.com/external-engin ... 7/936094_0
dougtoth
2005SLE PEARL
1975 MONTE CARLO
Post by dougtoth »
I went with the Duralast.
It has a lifetime warranty.
I have already got 3 of them at N/C which I use on all my Bonnevilles.
Louiej99
Year and Trim: 2002 Bonneville SSEi
Post by Louiej99 »
Girlfriend's LeSabre had the pegged oil pressure gauge problem. Then one day it started using oil. When I changed the oil, I changed the pressure sender (it's right above the oil filter). It was pretty slimy so I suspect it was leaking. Engine hasn't used any oil since.
It was a bit of a pain, but I used an adjustable wrench. Took maybe 20 minutes to get it out due to limited area for wrench movement. I used the BWD brand sender from Advance Auto. It's been in since May and so far so good.
Jazzy
Year and Trim: 2000 SLE; Arctic White, camel
interior; moonroof
Post by Jazzy »
I replaced the oil pressure sending unit on my 2000 SLE about 1,000 miles ago, and since then have not had to add a drop of oil. I had been going through a quart about every 800 miles from a slow leak some place or other or burning oil. But it now seems it was just leaking at that oil pressure switch. I bought the AC Delco one and a $6 socket to fit it from Amazon.
Favorite other cars I've owned:
2003 Lincoln Town Car, Cartier Edition (still have it)
1996 Chevrolet Impala SS (favorite car ever)
1995 Corvette
1989 Toyota Supra Turbo with 5-speed
1979 Mercury Colony Park Station Wagon
1974 Pontiac Trans-Am (455)
1957 VW Beetle
1957 TR3
