How to bleed brakes after replacing master cylinder lines?
2000_bonne
Post by 2000_bonne »
So the master cylinder reservoir was not dry, but anyways I had to replace the two lines from the M.C to the ABS module.
Is there any special way to go about bleeding it? Do I just pop open the caliper screws and wait for things to bleed like normal?
Right now it has little or no braking power. It barely had any before because one of the M.C. lines was leaking real bad.
Thank you.
96 SSEi
Re: How to bleed brakes after replacing master cylinder line
Post by 96 SSEi »
hi, i would bleed all 4 wheels .
fill mc.
pump brakes till it stiffens -
with pedal down
open bleed screw - close bleed screw
now let pedal up and pump
repeat till just clean fluid comes out
do this to all wheels
go for drive and engage abs on sand
if it still soft, bleed again all 4
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
Bleed all 4 like normal. You definitely have air in the lines.
