For starts, I have read the info contained in http://www.pontiacbonnevilleclub.com/fo ... 24362.html.
I am planning to do all the fixes required for an "upgrade" although the end goal is not more performance, but doubling its life (yes: it will be a dinosaur among all the electrical vehicles by then).
A few notes:
- The car has 180k.
It has a visible coolant leak on the front.
SC was replaced a few 50 kmiles ago (with factory pulley size)
The trans was rebuilt at 100k (but I now feel ripped off since it is failing again, already).
Engine mounts are new (OEM).
Drive axles are new.
Shocks and springs are new.
I own an actron CP9185 that can read OBD1.5
* Replace all engine gaskets, inspect what needs to be (I need help for the list of things to watch for inside)
* rebuild the transmission with performance parts (I don't want to do it again 75kmiles down the road)
From the article, here is my list:
- - New fuel pump Walbro 255
- Fuel injectors need to be cleaned and flow matched within 3 to 5% - replace otherwise
- Check fuel pressure after fuel pressure regulator (Target 2.7Bars)
- Replace O2 sensors with new AC/Delcoor Denso
- Replace lower intake manifold gaskets
- Replace lower plastic coolant bypass with aftermarket steel replacement
- Replace all idler pulleys
- Replace water pump with AC/Delco with a cast (not stamped) impeller.
- Replace Belts with Gates or Good Year Gatorback
- Fix the exhaust manifolds (Mine are definitely cracked)- - Install exhaust gaskets as well
- see viewtopic.php?f=12&t=23880
- - use sonnax update components
- use Transgo 4T60E Jr. shift kit
- New known-brand torque converter (brand TBD)
This is not my daily driver (anymore) and I am going to take my time to do it (between the job and the family).
Any thoughts?
Thank you.
