Change to supercharged?
Twystedhemp2
Year and Trim: 1995
Post by Twystedhemp2 »
Hello. I have a 1995, non supercharged model,now over 200k miles and the opportunity to buy a supercharged model engine. How difficult a replacement is this?
Detailpro116
Year and Trim: 96 Bonneville SSEi
Re: Change to supercharged?
Post by Detailpro116 »
Good news. Just talked to gmtuners and they have compatible software that will work, so I’m going to give it a try and see how it works out!
'96 Bonneville SSEi - White on Teal - ZZP Stage 1 Kit, 3.6" Modular pulley, ZZP ported TB w/spacer, L3 short ram intake w/K&N filter, ZZP Power Log, ZZP DP w/high flow cat & 97+ manifold, ZZP SC coupler, ZZP HV ignition coils w/10.5mm plug wires, 16" Gold crosslaces w/Yokohama Avid tires, Olds LSS T-handle, Sony HU.
2000 Buick LeSabre Custom - Daily - Sony double DIN headunit, ZZP plug wires, ZZP TB spacer, L3 short ram intake - Dark Bronzemist Metallic on taupe
Jdwcrw04
Year and Trim: 1994 White on white SSE
Post by Jdwcrw04 »
Compatible software for 1995 model? For tuning? That is good news.
To answer the OP question, anything is possible with enough time and money. To keep it as simple as possible, swapping the driveline from the same model year will provide the fewest headaches. You would need the wiring and PCM etc too...
