Coil Packs
devdude
Year and Trim: pearl white 2005 GXP
Coil Packs
Post by devdude »
I am receiving an error code indicating that cylinder 8 is misfiring. I have replaced the spark plugs but am still missing. The next step is the coil pack. I have the early version pack with the white epoxy. Since they are out of production the only way I can buy them is if I get the whole rail of four packs. It is cheaper to get the newer packs with the black epoxy. My question is can I change to the new design without issue? And if I only change the one bank will that cause issues with the other side of the engine still running the old design coils?
96 SSEi
Re: Coil Packs
Post by 96 SSEi »
hi, you can check the wire also - seats properly and no fraying. swap it with a good one to test.
PLUG,WIRE,COIL,ICM,CPS,PCM is the backward order of ignition.
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
CMNTMXR57
Re: Coil Packs
Post by CMNTMXR57 »
Have you contacted Andrew (Harofreak) on this board. He may have an individual coil.
As far as mixing and matching, you should be fine. There may be numerous updates with the newer ones, but I think the main one is the spring adjuster where they make contact with the plug that had a revision for better contact.
Daily Drivers:
2011 Camaro SS
CMNTMXR57
Re: Coil Packs
Post by CMNTMXR57 »
96 SSEi wrote:hi, you can check the wire also - seats properly and no fraying. swap it with a good one to test.
The newer LD8 N*'s don't have wires. It is a CNP setup with a direct coil over plug.
Another suggestion, swap coils with a working cylinder and see if the misfire transfers with it. That'll tell you whether or not it's the coil.
Daily Drivers:
2011 Camaro SS
CMNTMXR57
Re: Coil Packs
Post by CMNTMXR57 »
LD8
Daily Drivers:
2011 Camaro SS
96 SSEi
Re: Coil Packs
Post by 96 SSEi »
ooooh...lol
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
Re: Coil Packs
I have what you need, PM me.
DRWBRTq19
Re: Coil Packs
Post by DRWBRTq19 »
What car is the above LD8 out of?
Drew
Pontiac stable:
2005 Bonneville GXP - Black -daily driver
2004 Sunfire - Arrival Blue Metallic -Wife's
1998 Grand Prix GT - Black -seen better days, awaiting fate
1985 Fiero Sport Coupe - Black (mostly) - long term rebuild
CMNTMXR57
Re: Coil Packs
Post by CMNTMXR57 »
Are you referring to the pic above that I posted?
If so, that is out of a 2005+ LD8 in a RWD STS. The give away is the TB and the VVT actuators ("cam phasers" in GM speak). :)
I just picked a picture of a newer N* that had the modular coils we reference.
Daily Drivers:
2011 Camaro SS
