air shocks
chipgxp
Year and Trim: 2005 bonneville gxp
air shocks
Post by chipgxp »
hey guys,need some help.all of a sudden my gxp is riding like a buckboard.dont hear the compressor comming on ,so i assume the rear shocks have no air.i see in the trunk there is an air nozzle,but it wont take air and when i put a gauge on it,it reads 0.please help .
96 SSEi
Re: air shocks
Post by 96 SSEi »
hi, here is your manual............http://www.vadengmpp.com/owners-manual/ ... eville.pdf
page 1-115 is fuses - its #45 for air pump - check that first pl.
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
RJolly87
1994 Buick Regal Custom
Re: air shocks
Post by RJolly87 »
That nozzle in the trunk is actually for using the onboard air pump as an inflator to air up things like tires, balls, etc. There should be no air coming out of it or pressure building from it unless switched on using the nearby trunk switch.
The air system is designed to level off the rear end as weight is added loading the car down. Ideally, the car should set level with no extra weight in the rear. Usually the Factory service manual advises to confirm correct operation by throwing 300lbs of ballast in the trunk (causing a visibly low rear end) and then turning on the key. The car should fire the compressor within 30 seconds, and level off soon after that. You can also turn the key on, and with the trunk open, sit on the trunk lip, and it should get to work soon after sitting.
~Randall~
