2005 bonneville gxp
2005 bonneville gxp
hello,newbe here.just purchased a 2005 gxp.any sugestions about this car would be appreciated.love the performance so far.anything i should know? thank you
Re: 2005 bonneville gxp
hello guys,my gxp d i c keeps flashing low coolant and windshield washer fluid.both are full. any sugestions?thanks
- nos4blood70
Welcome!
Go check out the GXP section. You'll find most of the stuff you need there, or run a quick search on GXP items.
thanks.will do
- skregal
- Posts like an L27
- Year and Trim: 95 SSEi
05 GXP - Location: Missouri
Make sure that coolant reservoir is not going down
or losing fluid. It should maintain a fairly constant
level when checking it with a cold engine. If you have
to add coolant, you are in trouble.
The DIC message is probably caused from a bad level
sensor in the reservoir. You have to replace the entire thing
as the sensor is not sold separately. if you choose not
to replace the reservoir, please keep a eye on that coolant
level, you can ruin your engine if it runs low on coolant,
and these Northstar engines are known for that.
thanks very much for the info.will keep an eye on coolant level.its been down twice ,but only about a pint each time.
