92-95 SSEi lip added to 00+ bumper
2003 SSEi
Year and Trim: 2003 SSEi.
LOTS of Mods
Post by 2003 SSEi »
****Make sure you have the Photobucket plug in to see the pics****
I have successfully added the 92-95 SSE/SSEi front Lower Lip to a 00+ SLE/SSEi front bumper. If we take a look back at how this came about, sometime in around 2001-2002 i remember seeing a 92-99 SSEi with the front lip busted off and it just happened to be parked near a 00+ SLE or SSEi. when looking at the front of the cars it was painfully obvious that GM gave up on the design of the car below the fog lights. I always had it in the back of my head I would make this happen......
I started with a Junkyard 00+ bumper and a 92-95 lower lip.
I had to do a ton of fitment and marking of the bumpers. The 92-95 lip was actually cut into 3 separate pieces and shortened width wise to make fitment work
SEM Problem Plastic was used to bond the 2 plastics together
The Center section was cut and shortened to fit between the fog lights
To make the transition between the two smooth, a combo of SEM and Lord Fusor 114 for plastic was used.
I used SEM bumper bite that is made specifically for smoothing of bumper repairs
I also wanted to make some room for airflow if i ever wanted to remove the front license plate filler for the Intercooler
Pretty close in this picture, ready for some primer
figured i would test fit before paint just to make sure
after all the filling in and smoothing, and filling and smoothing, and filli.....well you get the point
and of course the final product
J Wikoff
Year and Trim: 1992 SSE
Re: 92-95 SSEi lip added to 00+ bumper
Post by J Wikoff »
I think it looks great!
haro1225
Year and Trim: 2004 GTO
Post by haro1225 »
That looks pretty good. Just when we think you’ve done it all, something else cool gets added.
-Ryan
2013 Audi Allroad Quattro
yourgrandma wrote:Hi.
petraman
2013 Audi A4 6MT
Location: ............ Granville, Ohio/Erie, PA *WCBF '08 SURVIVOR* *NEBF '07 SURVIVOR*
Post by petraman »
Coming out of the woodwork just to say that it should have come from the factory like this. The 00+SSEi's always looked like they were missing a lip, and the one you added blends in perfectly. Great job. =D>
(oh my god, it's worse than I thought... first post in three years, geesh...)
2013 A4 P+ ------------------ Glacier White Metallic
6MT, Sport Pkg, JHM Stage 1 Clutch/LWFW, JHM Short Shifter, JHM HFC, USP SS Clutch Line, CR-15 Strut Bar, Alu Kreuz, BFI Shift Knob, EC Trans Mount Insert, VCDS tweaks.
95naSTA
Post by 95naSTA »
That looks great Pat.
I actually have 2 lip kit attempts for my 95 in my basement from like 6 years ago. One from a 92-95 and the other form a 96-99 SLE.
TheCollector
Year and Trim: 1992 Bonneville ssei
Post by TheCollector »
it looks beautiful. if i find one like that i might buy it and sell my old one since i have some problems with it.
Life sucks, And then you Die.
96 SSEi
Post by 96 SSEi »
nice!!
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
