compatibility range
rustler85
- LE Member
- Year and Trim: 1992 bonneville SE
compatibility range
quick question for the forum.. need some help finding some fenders but the 92 is kinda scarce, is there any other years that the body is compatible with without having to change the full front end?
Re: compatibility range
92-95 should be the same, as far as I know.
- J Wikoff
- Year and Trim: 1992 SSE
^^That's the range. Any older won't even mount without mods. Any newer will require changing out the headlights/cornerlights and maybe the bumper and grill to avoid interferences or weird gaps, and I am not positive if the front of the fenders mount the same or not.
