Service security system . And driver rear door no power lock
beeman212
Year and Trim: 2000 Bonneville ssei
Post by beeman212 »
Bought car and rear windows didnt work so with info from here i fixed the wires under driver seat and everything worked and while i was on vacation the driver rear lock wouldnt lock unless manually locked.
Then a month later my key fob quit working and tested batt and its good so i changed it anyways and still nothing..
So i tried reprogramming it with tech 2 scan tool and it wont sync it.....
I have power in rear door and if u use tech 2 scan tool to try to lock the driver rear door u can hear a relay clicking in the door module and i also replaced the power lock mechanism inside the door and still nothing.... any ideas?
96 SSEi
Re: Service security system . And driver rear door no power
Post by 96 SSEi »
you have to let the fob relearn by standing infront of car and hold lock and unlock for 10 seconds - the car should cycle lights and horn and you is done for relearn
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
