Coolant problem
Coolant problem
My 2002 SSEI coolant keeps disappearing. This is my first ssei. Haven't noticed anything around elbow or pump or anywhere else for that matter. Car runs fine and mileage is still 21-22 as normal. Wondering if there are any known problems such as the non supercharged intakes that I can look at for a problem. Thanks
96 SSEi
- Posts like a Northstar
Re: Coolant problem
hi, please take a careful look at the left side of engine and see if the coolant is leaking from the water pump weep hole - how much coolant are you losing?
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
Re: Coolant problem
I had filled the overflow tank to proper level about 3 weeks ago. Noticed this morning about an inch left in it. And I will check again. I'll park on a clean surface also. Maybe I just missed it. And i haven't pressure checked yet either.
96 SSEi
Re: Coolant problem
yes, find out if its leaking and from where - when the car is at full operating temp( 200f) do you have good pressure from the upper rad hose or is it easily squeezed?
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
- nos4blood70
Re: Coolant problem
Check your oil for milkshake and moisture. Lower intake manifold could also be a problem.
Re: Coolant problem
Last time my 2001 SSEi had a leak with signs like yours, the upper passenger side of the radiator developed a hairline crack. Took me a while to pinpoint the crack. Over time the crack got bigger and then tiny pools of coolant were found after filling the coolant overflow and driving in hot weather (then parking).
Most likely it is a coolant elbow or a LIM gasket, but wanted to mention the radiator issue I had.
Re: Coolant problem
I haven't noticed any visible leaks yet. I'm gonna try to pressure check this weekend. Top hose is tight when trying to squeeze when at operating temp. Oil is correct level on dipstick. No signs of milkiness either. Car gets about 100 miles a day put on it. At 95k now. Only been through 1 winter. Stored the rest.
MKMike
- Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Re: Coolant problem
Another area to look at carefully, is below the supercharger. Often coolant pools there when the SC engine's LIM gaskets are failing.
There are other signs of failing LIM gaskets at GM 3800 Tips on Facebook.
It's an excellent list as it puts the symptoms in order of the severity of failure.
https://www.facebook.com/GM3800Tips/pos ... 8071634026
