2000 SLE read zero on oil pressure gauge then goes up
Bonneville'sRock
Year and Trim: 1995 Bonneville SE
2000 Bonneville SLE
Post by Bonneville'sRock »
Greetings, I have a 2000 SLE with 205k. Noticed yesterday upon start up no oil pressure...yet no motor noise...shut off right away. Started today and again no pressure upon start up...let idle for 5 min. and pressure climbs to 40PSI.. Repeated procedure....no pressure on gauge then climbs to 40 PSI after about 5 min. Changed oil and filter. (Wix filter)...no difference.....no motor noise....any ideas?
MKMike
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Re: 2000 SLE read zero on oil pressure gauge then goes up
Post by MKMike »
Since the pressure sensors so often go bad, it could be the problem.
See http://www.pontiacbonnevilleclub.com/fo ... 25362.html for the most common issues.
An oil pressure tester is the only way to know what the pressure truly is.
Perhaps one can be borrowed from a local Autozone.
If not, you might just buy a pressure sensor and see if the problem is fixed since it's cheaper than an oil pressure tester.
Normally when these sensors fail they just peg at 120 PSI. However, recently we have seen more fail and just drop to zero. It wouldn't be out of the ordinary. 0 PSI would certainly be felt in the motor's behavior.
stahrman01
Year and Trim: 2001 Pontiac Bonneville SLE
Post by stahrman01 »
My son's 01 SLE was doing the same thing. Changed out his oil pressure switch during his next oil change......problem solved!! :bwoohoo:
Bonneville'sRock
2000 Bonneville SLE
Yes, it was the oil pressure sensor. ($42.00). Thanks everyone!
MKMike
1998 SE
2001 SSEI
2002 SSEI
Post by MKMike »
Thanks for reporting back.
Glad to hear it was just the sensor.
