Good Navigation Systems?
jaycay99
Post by jaycay99 »
So I have a '01 SSEi, and I want to upgrade the stock radio to a Navi. Do you guys have any recommendations that work well with the bonnevilles? Perhaps one that fit in nicely were the stock radio is?
Thanks Everyone!
96 SSEi
Re: Good Navigation Systems?
Post by 96 SSEi »
leave it alone and get a tom tom - the space is not enough for a good screen i see in newer cars
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
You can install a double DIN head unit that has GPS. Costs can vary, and installation is a pretty involved process. You will need a couple of adapters (main harness, steering wheel, radio antenna, GPS), and to cut out plastic behind the radio in order to fit the unit. A double DIN will fill out the stock location nicely.
However, I would suggest that it is cheaper and easier to use an app on your phone if you have a smart phone. My personal favorite is Waze. Not trying to dissuade you, but the installation of the GPS in the car will be more for aesthetics than anything else.
Bugsi
05 Mercedes S500 4Matic
Post by Bugsi »
I'm a big proponent of my stand-alone Garmin nav unit. Kenwood makes double-din head units with Garmin navigation built-in. They have hit-or-miss reviews, and I've never used one, but that's what I'd probably go with if I wanted Nav integrated with a head unit.
`05 Mercedes S500
