An unusual situation, I need advice ASAP
bonnechuck
Year and Trim: 2000 SE
Post by bonnechuck »
2000 Bonne SE is sitting under a very heavy tree limb which is resting the roof of my house since 5 PM this afternoon (Sat the 14th). I have not moved it in the last year and a half and had to jump it to be able to release gear selector. Gear selector is stuck will not move, and I have tree service coming tomorrow. Any ideas on how to make it move? Harofreak and others have supplied great info over the years and I appreciate them and all the contributors to the board. Why I have not had it running for so long is a story I won't bore you with. Any idea to free up the selector will be appreciated. Thanks and a good night from Pittsburgh, PA.
96 SSEi
Re: An unusual situation, I need advice ASAP
Post by 96 SSEi »
hi, if you can insert key and the dash lights up, you should be able to select gear. if you cant, I would pop hood and look directly below master cylinder of brake system- the linkage you see connects to tranny and should move to selected gear
if it dont shift by drive selector, keep key in on position and try to mannually move the linkage to newt and if you are on an incline, the car will roll.if you have a good tree service, they will remove the limb and you wont have to move the car for them.
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
As stated above, disconnect the gear selector from the top of the transmission. You can then manually rotate the selector by hand.
bonnechuck
Still cannot get it into neutral. Top of the transmission moves but in any postion it is still not in neutral. Any ideas? Thanks.
96 SSEi
Post by 96 SSEi »
bonnechuck wrote:Still cannot get it into neutral. Top of the transmission moves but in any postion it is still not in neutral. Any ideas? Thanks.
hi, if you have a trolly jack, you could jack up the front and pull her out of the way - need flat ground or incline in the
direction of travel
you sure yo got p= brake off?
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
maxi426
Year and Trim: 2003 SSEi
1999 Park Ave. Ultra L67
Post by maxi426 »
If you moved the shift lever on the trans, and it still won't roll, it sounds like the brake pads may be rusted to the rotors
DCJREDLINE
Year and Trim: None
Post by DCJREDLINE »
BIGG ASSSSSS TOW TRUCK. Seems like the only option
2004 Saturn Ion 3 Quad Coupe
