Codes
Solid_speed
Year and Trim: 2002 ssei
Codes
Post by Solid_speed »
So, I'm sorry if this isnt the right section for this and plz feel free to put it in the appropriate section. I had my check engine light checked after noticing it flashing and the car stuttering under load and it turns out I have misfires. The strange part of it all is its also pulling up code p0243. My check engine light has always been on, and it was due to o2 sensor and catalytic converter. So the misfire and p0243 code is New. Any ideas on what would cause the code to come up? If it helps, I recently gutted my air box, but I'm unaware if this code has popped up since I gutted it because I only checked the light again because of the stuttering. Any help would be great thanks!
J Wikoff
Year and Trim: 1992 SSE
Re: Codes
Post by J Wikoff »
Something is wrong with the boost control system. What kind of boost pressure do you have cruising and at WOT?
There are two components, the solenoid and the actuator. The actuator is active all the time. It's round, black, has a couple vacuum lines running to it, and a rod sticking out the bottom. The solenoid is a small black box near the actuator with a vacuum line running to the bottom of the actuator, and a wire harness running into it. It's only active when the PCM doesn't want boost, or less of it, and manipulates the vacuum to the bottom of the actuator.
In my experience, stuttering has been caused by the solenoid.
Oldman
Year and Trim: 2001 SSEi
Re: Codes
Post by Oldman »
I would check the vacuum lines to those two components. I had the same problem and just stopped up the vacuum lines going to those two items. Everything is fine now. A buddy of mine told me basically what they do is not allow boost in reverse. That sounded stupid to me, but I traced the vacuum lines to those items and blocked them off at the source and boost works fine and the code went away. No adverse effects that I can see to this.
J Wikoff
Re: Codes
Post by J Wikoff »
The boost would work fine, until the PCM wants to dump boost, like if there's knock happening. If it can't dump boost, knock quickly gets worse and then stuff breaks.
Solid_speed
Re: Codes
Ok, so i went and got my misfiring taken care of (bad coil). At cruising speeds I'm at just under 0 boost. When I give it power I'm getting about 4 use to get 5 after gutting the air box.
Solid_speed
Re: Codes
Oh and the stuttering is no longer happening
J Wikoff
Re: Codes
Post by J Wikoff »
Good to hear the stuttering was fixed. Did the P0243 go away too? Your boost seems low to me. I thought Series II's ran around 7 psi.
Solid_speed
Re: Codes
Yes the P0243 is gone but I'm not sure if it's just because they cleared the check engine light or not? Since I've had it, it's always had 4lbs of boost and since gutting the air box I got 5. I'm not sure if what is supposed to be? Perhaps someone with the same engine cloud elaborate?
