Trunk seal adhesive
SurfingBonnedriver
Year and Trim: Former 01 SLE Owner
Trunk seal adhesive
Post by SurfingBonnedriver »
What kind of infernal goo does one use to glue the trunk seal down? Not sure what factory used, local leak detector guy used silicone, I tried 3M weatherstrip adhesive black. None seem to get quite the bite I am looking for.
Sadly, I am selling the Browneville. 123K miles and I found a Subaru Outback that will hold my surfboards, all but one of which will not fit in the Bonne. Whilst making the sale, I discovered that the spare well was full of H2O. I suspect the trunk seal as the culprit. I have thought of using water based markers to make sure. Prospective buyer is taking delivery tomorrow, but I'd really like to have this taken care of before I send 'er off.
Here is a parting shot of her detailed up for the sale.
and finally the place where one night I lost my.........
KEYS - y'all get your mind out of the gutter.
2004 Subaru Outback Wagon - 2014 Equinox - Crystal Red Tintcoat - 2001 Dodge Dakota Quad cab 4X4(beach truck) -
Re: Trunk seal adhesive
Hahaha, that last part had me thinking…
Are you sure it is the trunk seal? In any case, I'd try silicone again, some high quality architecture grade stuff if possible.
DCJREDLINE
Year and Trim: None
Post by DCJREDLINE »
Ive always used the 3M yellow.
I fought with the leak in the trunk of my Bonne when I first got it too. If I remember right mine was coming in one of the mounting bolts of the tail lights. It most definitely was not the trunk seal but yours may be.
2004 Saturn Ion 3 Quad Coupe
SurfingBonnedriver
Well folks, she's gone to serve yet another master. Someone will be getting a good Christmas gift. FWIW, the 3M glue worked, I was impatient waiting for it to cure. I went out the next AM, and the weatherseal would not budge. I found a wing mount bolt that turned about a 1/4 turn and had rust on the washer, hopefully that and the trunk seal will solve the issue. New owner is thinking about installing self bilge holes with screens. Not sure, sounds like a good way to get CO in the cabin with the SLE exhaust tips just a few feet away. Could also be rear reflector upper clips. I had pulled the reflector, and managed to salvage the clips, but also provided a bag full (7) of them from an Alero to the new owner. I used 3M mounting tape in place of the gasket to ensure if the clip did not grab, the 3M did.
UPDATEFound leak, I dried out the trunk and it rained buckets here yesterday. Met new owner today to transfer the service manual and found the leak in the rear quarter/rear clip seam midway down the trunk lip on the passenger side.
Thank you to all the help I have received from this forum, I'll keep checking in as I am still working on a rear reflector permaseal solution. I think I might be onto something and will keep y'all posted.
SurfingBonneDriver signing off....
