Air Intakes
stephenssei
- Year and Trim: 1994 SE
Air Intakes
Hey I've been looking around everywhere for a good cold air intake for my 94' SE and I want to buy one but I want to make sure for certain that it will fit no problems
- 95naSTA
- Year and Trim: 95 SLE
Re: Air Intakes
You'll have to make one. The popular method of choice 10 years or so ago was to get a 92-95 3" short ram civic intake, ditch the cheapo filter, block off the posts, get a K&N, and make some sort of heat shield.
Schlotzky
- SSE Member
- Year and Trim: 1997 Buick Park Avenue Ultra
Re: Air Intakes
Just go to eBay and get a cheap ChromeIntakes type intake. They are a simple bent aluminum tube with necessary hardware and sensor hole and are actually pretty decent quality. Spring for the version with the K&N cone filter, and you can make a heat shield if you're so inclined.
2007 Jeep Commander Overland Hemi
<\>1998 Oldsmobile Aurora
<\>1995 Buick Park Avenue Ultra
<\>1996 Chevy Camaro 3.8L
fmacnak
- Year and Trim: '95 SSEi
Re: Air Intakes
So what do you make the heat shield out of normally? Any thoughts on a scoop for true ram air?
95 SSEI (modified-cammed, ported & portmatched, custom Positraction trans)
99 C5 (too original-can't bear to make it a project)
09 Escalade (to tow my projects around)
03 Bmw 330 Cic (the foreigner)
Re: Air Intakes
Intense intake can be make to work or you can go to www.Siliconeintakes.com and make one
Shane "RedZMonte"
2004 Z16 Z06: Virgin
