I was just wondering what a shop charges from the book, and the hours listed to replace the main engine wiring harness on an 03 Bonneville SE.
Max
Shop charge to replace the main engine harness
max harris
- Year and Trim: 2003 SE
Re: Shop charge to replace the main engine harness
Did you have a fire?
- RJolly87
Or a Vermin?
~Randall~
max harris
No fire, and no vermin under the hood. The main harness had a short in it that caused #1 cylinder misfire. I replaced it on Friday in about 4 hours while sipping on a beer and talking to the neighbors. I was just wondering how much a shop would have charged.
Goostoff
- Year and Trim: 2000 SE. 2000 SSEi, 2001 SSEi, 2002 SLE
I cant imagine that job taking much more than an hour in shop conditions with no beer or interrupting neighbors. If you consider when I pull and engine I always just unplug everything and lay it off to the side. I can have a whole engine out in about 2.5 hours.
I would imagine it would call for 4-5 hours @ ~100 an hour. I did my OBDII swap (harness and ecu) in about 5 hours.
S
S
Shane "RedZMonte"
2004 Z16 Z06: Virgin
