GMOS-09
irish91983
1992 Bonneville SSEi (Sold)
GMOS-09
Post by irish91983 »
HI All
I just bought my GMOS-09 I was wonder is there a certain way to wire it up? I noticed that is does have a couple extra wires Blues and reds. Just want to make sure before i go forward.
Thanks Keith
2001 SSEi Bumbles
Angel Eyes ~ Cleared Corners ~ Tinted Tails ~ Intense FWI ~ 20% Tint ~ 180 Drilled T-Stat ~ GXP Brake & Suspension Upgrade ~ Alternator Rewire ~ Intense Shift Kit ~ Headers ~ Tr 6's
Fan over ride~NGK Tr 55's~180 Drilled t-stat~Clear Corners~Angel Eyes~Tinted Tails~Magnaflow Cat
Re: GMOS-09
What radio do you have? Are you running a separate amplifier or the stock Bose one?
It should have a schematic. But basically, you should have a ground, constant power, switched power, illumination, and then speaker leads depending on whether you're using them or RCA cables. The latter is dependent on whether you have the stock amp or an aftermarket one.
irish91983
Re: GMOS-09
I will be running the stock Bose amp. I have a Kenwood DDX719.
2001 SSEi Bumbles
redzmonte
Year and Trim: 2000 SSEI
Re: GMOS-09
Post by redzmonte »
should match all up to the Kenwood harness. The instructions tell you to "Cut" one of the wires if you have bose and another if you have Typhoon. other then that i matched up all the colors and it all works.. I have a Kenwood DDX512
Shane "RedZMonte"
2004 Z16 Z06: Virgin
irish91983
Re: GMOS-09
I dont remember it telling to me to cut a cretin wire. But I did notice that my rear doors speaker wont work on Bluetooth but work when a cd is playing.
2001 SSEi Bumbles
