What did you do to your car today?
FiendScurro
Re: What did you do to your car today?
Post by FiendScurro »
Did rear brakes yesterday. Both calipers were seized. Now have reman calipers raybestos advance tech rotors and wagner thermoquiet. Also replaced purge vent solenoid while I had her ass up. Breaks are spongy even after I bled the system. Might have to bleed the front calipers or just get a fluid flush. Do they bleed the system when they do a flush?
Dan
Scurro
haro1225
Year and Trim: 2004 GTO
Post by haro1225 »
I finally replaced that hood cable on the 96 GP. What a pain that was, but at least there's not a cable sticking out of the grill anymore.
-Ryan
2013 Audi Allroad Quattro
yourgrandma wrote:Hi.
spoiledred94
Post by spoiledred94 »
Bought Power Stop D/S Rotors (name brand) for the front/ I'll hopefully pick up the better version of the wagner ceramic brake pads in a couple weeks. I wanna do all four when I have the $ and rebuild and paint the calipers. If I wait it could be a very long wait.
great car. Wrecked
Burnt Bonny.
1oldman
Post by 1oldman »
Saturday the wife and I washed her CTS and the '05 SE. Today I waxed her CTS with Meguire's NXT Gen Tech Wax II.
techweenie
Year and Trim: 2004 GXP
Post by techweenie »
I ripped apart the driver side of my GXP today. God d***it I hate aluminum control arms and knuckles. The wheel bearing is seized into the knuckle, and the ball joint rivets are seized into the control arm. Rather than f with it for three days I'm just gonna replace the whole control arm. I had to cut the stud off the tie rod end to get that separated, so this "little" project just turned into a bunch of new parts. All I wanted to do was replace the output seal, cv axle, and ball joint.
2004 Bonneville GXP Greystone Metallic - all stock
2002 S10 ZR2 - my favorite truck in the world
1998 K3500 CCLB - motor rebuild in progress, future mud truck
1994 S10 Blazer - 5" lift, narrowed ZR2 rear end, 32x11.5 tires, parting out due to overwhelming rust
haro1225
Post by haro1225 »
Today I washed and changed the oil on the 04, then I changed out one of the rusted out mufflers on the 96. Also I Plasti dipped the hood vents and saw that somebody had modified the stupid sealed beam headlights to take 9006 bulbs. So in went the 9012's that I had in my other non retrofitted headlights.
-Ryan
2000Silverbullet
Post by 2000Silverbullet »
Today I installed a cold air intake cone on the Goose. Got tired of not hearing the whine!made my special cold reflectex box.
Datbonneville1
Year and Trim: 94 pontiac bonneville se
94 buick lesabre
Post by Datbonneville1 »
Replaced a fuel pump and filter and part of a fuel line! and last week i did my UIM and LIM gaskets!
PRD2BDF
Post by PRD2BDF »
Installed a strut tower brace on the Saab and ordered a CAI. Waiting for it to arrive. Next will be mufflers delete.
2000Silverbullet
Cleaned the MAF sensor in Bullet. Also reactivated the water injection system.
I was getting significant KR without it.
Quite a difference in this warm weather.
Drops after SC IAT by 50*F
haro1225
Post by haro1225 »
I painted the mismatched wheels on the 96. I did the lip on them with the same silver as my GXP wheels, and did the laces body color. Don't mind the overspray on the tires.
-Ryan
Blown93SSEi
Year and Trim: Dark Green 1997 SSEi
Post by Blown93SSEi »
Nice paintjob!
Today I Started repainting the passenger side view mirror. Have it sanded and primed right now just going to let it set a bit before I put the green on. Also tried putting some protectant on the dash since it's starting to look pretty bad from the years and heat.
Washed her in and out also and scrubbed the wheels. Very shiny.
Jacob, Dark Green 1997 SSEi "The Green Lantern" Over 268,000 Miles and Still Going Strong!
Mods/Stuff: INTENSE! FWI, ScanGauge 2, Mobil 1 HM Oil, Valvoline HM Transmission Fluid, Mildly Tuned PCM, Drilled 180 Thermostat, Cleared Corners, Silverstars, Chrome T-Stars, NGK Iridium Plugs, NAPA Belden Wires.
Zeik75
Year and Trim: 1988 LE
2000 SSEi
Post by Zeik75 »
Plugged in my new aeroforce and did some cruising to test that, everything is looking great so far no KR except for launches and nothing else is reading bad. Now to get it mounted!
-Austin-
spoiledred94
Thats great. How hard was it to get it right? where will you put it?
great car. Wrecked
Burnt Bonny.
spoiledred94
Drove 300 mi RT to a nice loc on the coast. Handled and performed beautifully. We rode casual. I had to pass a guy on a 2 lane highway with a lot of traffic on the way back. When I opened up so did he. He had it floored imho but I caught him and left him behind. Not real legendary. I just was happy as can be with Our car/
Got an avg of 24 mpg and used about 10 gallons. Got EGR code. I just cleared it and it hasn't popped up again
great car. Wrecked
Burnt Bonny.
ShaneC
Year and Trim: 98 Bonneville SE 3800 S2
Post by ShaneC »
Well mine is really what I've done over the last three days since I was working 12 hours, working on the car, sleeping and working another 12 hour shift, replete lol. (will add picture to Midnight own forum after he gets back from the shop this weekend)
1: finished the hood: last bit of paint, sealed it, buffed it, waxed it and polished it.
2: spray painted the entire grill black, then I painted the Pontiac symbol and the trim(was silver) the same color red as is on the wife's grand prix
3: new tire (only two more to go lol)
4: put new Eagle Eye front lights and a pair of smoked (can't remember brand name) taillights on the Grand prix
And that covers what I did on my car today(s)
They call me...Snowflake
Mine:1998 Pontiac Bonneville SE 3800 II 250k miles (Bad engine)
MODS: all chrome lug nuts, ported UIM LIM, 180 T-stat
In Progress: Finished overhaul under the hood, & updated interior.
OURS(DD): 2003 Pontiac Grand Prix 3100SFI 165k miles MODS: custom lights both front and back
Hers: 04 Pontiac Aztec Base model. More to come later
FINN444
Year and Trim: 2003 SSEi
Post by FINN444 »
I just installed my "Supercharged" 3rd Brake light overlay that I got from vinzdecals.com...looks pretty good so far!
John
2003 SSEI - Nighthawk
Performance: Boat Roller Mount, Intense FWI, Moog Polyurethane End Links, 180* tstat, silicone vacuum lines
Appearance: "Supercharged" 3rd Brake Overlay, LED Interior Lights, RallyArmor Splash Guards, Red Calipers, HID retrofit, black GXP rims
Audio: Nothing... yet!
1998 ssei
Year and Trim: 1998 SSEi
Black
Post by 1998 ssei »
Replace my right front hub after feeling some shaking in my steering wheel, I pulled over and saw 2 lug nuts holding my tire on! The rest had been broken off. Not sure how that happened. Got it towed home. Wasn't too bad of a job.
1998 Black SSEi, All original with no mods (214k miles) Daily driver {purchased in 2003 with 39k miles}
2010 Black Camaro SS, muffler delete, CAI, Diablo tune, carbon fiber hood (60k miles) Weekend driver {purchased new 2009}
2014 Metallic Green Explorer, no mods, (45k miles), vacation/road trip driver {purchased new 2013}
haro1225
Post by haro1225 »
I rotated my tires today, and I got a polisher yesterday. Once I get my supplies I have a couple cars to practice on, pics will happen when I get them done.
-Ryan
1oldman
Post by 1oldman »
Worked on the '05 SE. Replaced the incandescent map, courtesy and trunk lamps with LEDs, swapped the ICM out of the '92. The '05 had been acting like it wanted to miss when I bought it, even after the youngest son had replaced the LIM gaskets, Plenum, plugs, and plug wires. I had swapped the coils with the '92 afterwards too. The ICM swap cleared up the "almost" miss. The car runs better the more it gets worked on and driven. - BC
