A/C freon doesn't even reach condenser from low-side port
Junior28
Post by Junior28 »
As suggested from the subject line, I put freon in on the low side and it doesn't seem to even reach the condenser (line doesn't get cold...). Now, the condenser is bent and MIGHT be inoperable, but with the freon not even making it to the condenser, would the condenser even be the culprit? If not, any other suggestions on why I am having this problem?
There doesn't seem to be any holes in the line leading up to the condenser either.
david
Year and Trim: 2000 bonneville sle , 2002 gtp
Re: A/C freon doesn't even reach condenser from low-side por
Post by david »
did you vac down your system? did it hold ? If you put to much freon in your ac it will not work.
What does it profit a man to gain the whole world and lose his soul.
RJolly87
1994 Buick Regal Custom
Post by RJolly87 »
Ummm.... The condenser should never be cold.... How do you know it's not reaching the condenser?
I would check both system pressures to see what is going on, especially with parts we are not sure about.
~Randall~
