Simple enough eh? My question is where the heck is the 6th cyl plug? And how do I get to it to test?
'01 6th Cyl Misfiring?
twistedkeys
- Year and Trim: 2001
Hey guys, was just told by my mech that my 6th cyl is misfiring. "Could be the wires, or plugs, just takes a little diagnosing"
- nos4blood70
Re: '01 6th Cyl Misfiring?
Spark plug 6 is located closest to the driver.
Think of it this way.
2.4.6.
Engine.
1.3.5.
Radiator.
2.4.6.
Engine.
1.3.5.
Radiator.
twistedkeys
Crap. How do I get back there?
- spoiledred94
- Posts like a Northstar
It sounds like you might get in over your head. Its nearly impossible to tell a fuel system problem miss from an ignition problem miss. I suggest calling a good shop and asking for help or perhaps a craigslist Mechanic. My 01 cyl 6 was missing more and more. I replaced "EVERYTHING" thinking it was ignition but it turned out to be a bad splice on the wire supplying current to cyl 6 injector. You might also want to have it scanned for error codes. Autozone/Oreilly's etc. allows you to use their scanner no charge.
great car. Wrecked
Burnt Bonny.
great car. Wrecked
Burnt Bonny.
twistedkeys
Oh really? That kinda stinks. My friend looked at it and said that the plug wires in some places were crossing over each other which might cause a misfire? But he's not a certified mech. I winder how much it would cost for me to have a shop diag it...spoiledred94 wrote:It sounds like you might get in over your head. Its nearly impossible to tell a fuel system problem miss from an ignition problem miss. I suggest calling a good shop and asking for help or perhaps a craigslist Mechanic. My 01 cyl 6 was missing more and more. I replaced "EVERYTHING" thinking it was ignition but it turned out to be a bad splice on the wire supplying current to cyl 6 injector. You might also want to have it scanned for error codes. Autozone/Oreilly's etc. allows you to use their scanner no charge.
Could be a million things I guess, but I did have autozone check it and got that misfire error.
- nos4blood70
Check ignition before fueling. It's easier. With the motor cold, feel around behind it to find where the plug wire is going. Then after you take it off the plug, find the spark plug with your hand and put the socket on it. You have to "see" with your hands to do plugs on the back of a 3800.
twistedkeys
Nice thanks guys, looks easy enough!nos4blood70 wrote:Check ignition before fueling. It's easier. With the motor cold, feel around behind it to find where the plug wire is going. Then after you take it off the plug, find the spark plug with your hand and put the socket on it. You have to "see" with your hands to do plugs on the back of a 3800.
twistedkeys
Replaced the plug and wire, it's running better but still rough... Gonna replace the fuel filter and air filter then see what's up. Any suggestions?
- spoiledred94
You could try disconnecting the plug wire from the plug to see if there is a change in the performance. If not then you are not getting spark at that cylinder. If there is a change in performance then I'd say the cyl 6 ignition is good.
great car. Wrecked
Burnt Bonny.
great car. Wrecked
Burnt Bonny.
- nos4blood70
Swap the coils around. The coils are what feeds the electricity to the plug wires. You may have a bad coil. That's a simple thing to add to the check list.
