98 SE nned to disable ABS
Djkthegame
1987 Bonneville LE
Post by Djkthegame »
I use my 98 SE as a delivery vehicle and like all u other bonnie owners know Pontiac's ABS really sucks, can some tell me how to disable the ABS and where?
"CERTIFIED BONNIEHOLIC"
B I-1999 Bonneville SE -My First Bonnie- gone forever
B II-2000 Bonneville SSEi (black) 7/3/09 ZZpcm 1.0, Thrasher Cold Air Intake, Magnaflow hi-flow cat, 180 thermostat, Autolite 104's, solid hockey puck front mount, Intense 3.4 MPS. (OCT 2010 COTM Nominee)
B III-1987 Bonneville LE (burgundy) 7/22/10 -- Gone to Heaven
B IV-1991 Bonneville LE (black) 12/6/12 Parts Car -- Gone!
B V-1998 Bonneville SE (green) 9/11/13 -- 270,000+ and going strong! -- gone 287k+
B VI-1989 Bonneville SSE(gray)9/23/15
J Wikoff
Year and Trim: 1992 SSE
Re: 98 SE nned to disable ABS
Post by J Wikoff »
Disconnect a wheel speed sensor either right at the wheel hub or further up the harness where you find a connector. Pull the abs fuse. Disconnect the harness from the abs unit. Those options are what come to mind.
Djkthegame
1987 Bonneville LE
I saw where the unit plugs in under the air box I disconnected it there and wrapped up the plug to keep it dry, Thanks
RJolly87
1994 Buick Regal Custom
Post by RJolly87 »
I think you can pull a fuse for the system too.
~Randall~
