Can a brother get a picture...
Need For Steve
Year and Trim: 1994 Buick LeSabre Limited
Post by Need For Steve »
...of your thermostat?
Or at least a description of how you seated it into the gasket in your car?
I haven't been around the forums much in a while, but I've had this low operating temp problem for at least a couple years now. The car takes FOREVER to begin to heat up, and then runs dead in the middle between 100-200* on the gauge, fluctuating slightly. In a fit of preventative maintenance, I decided to replace my OE thermostat 2-3 years ago, and when I did I had to replace the OE rubber O-ring type T-stat gasket for the "improved" one. Well, the only thing I can figure is that I must have it installed wrong and it's letting coolant pass by, or the gasket is hanging the thermostat open?
So how in the world does that thing sit in there? A picture would be incredible :beerchug:
call me Steve...
HAI, full 2.5" exhaust, resonator delete, Pioneer Audio, F17 transaxle, Toyo Versado LX 215/70/15's
Need For Steve
Re: Can a brother get a picture...
Anyone?
Even just an overly dramatic explanation of exactly how yours sat in and went back together would help. I've tried three (3) new thermostats since this began happening and they all produced low temps, so it must be something I did wrong with the gasket thingy...
call me Steve...
imidazol97
Post by imidazol97 »
Need For Steve wrote:...of your thermostat? Or at least a description of how you seated it into the gasket in your car?
The slit on the inside of the gasket is where the thermostat metal edge goes.
Need For Steve
I really think that just solved it for me, thank you! That's definitely not how I put mine in :banghead: I think I just sat my thermostat right on top of the gasket (like the old O-ring was) and hoped it sealed. It isn't haha, so thank you!
Also, I've seen differing things about, when the thermostat seal is replaced, whether you need a thermostat housing gasket or not. I've seen that some people don't use them. I really don't know.
call me Steve...
imidazol97
Need For Steve wrote:I really think that just solved it for me, thank you! That's definitely not how I put mine in :banghead: I think I just sat my thermostat right on top of the gasket (like the old O-ring was) and hoped it sealed. It isn'thaha, so thank you!
You aren't the first that did that.
With the edge of the thermostat in the slot in the middle of the o-ring gasket, the ring squishes when the thermostat housing is tightened down. Coolant shouldn't leak around it.
I always wondered if the o-ring gasket should have the taper narrow edge down or up? I don't think anyone has addressed that.
Good luck.
Boreas
Year and Trim: 1993 SE
1996 SSEi
1997 SSEi 40th
Post by Boreas »
Narrow edge down.
I've never heard of people not using a housing gasket, unless they use gasket maker. I cant see how the gasket squishes, it should be flush on the manifold, which is where the second gasket for the housing comes in. The gasket is a mere ~$1.20 at your local parts store. Better be safe than sorry. :)
1993 Bonneville SE "Old Ironsides" 244,xxx - Junked.
1996 Bonneville SSEi "Double Trouble" 164,xxx - Stock
1997 Bonneville SSEi 40th "Purple Spaceship" 204,xxx - Aeroforce Interceptor, B&M 70264 Trans Cooler, Intense FWI, High-Flow Feline, non-Bose head unit w/ 5 band, Alpine 6x9's, 3.5 MPS, SD Headers, rear disc brake conversion. Future: 1.9 Rockers
1997 Buick Park Avenue "Blue Floaty Thing" 124,000 - Daily Driver/Winter Beater
