driven sprocket support wont go in the way
- wdudetocool
- SSEi Member
- Year and Trim: 2000 se
its sticks out about 2 or 3 mms above case where i cant put cover on. what am i doing wrong?
Re: driven sprocket support wont go in the way
Are you talking about the 4th clutch hub? Push it in further. Twist and push at the same time.
- spoiledred94
- Posts like a Northstar
I hsd the same problem. Turned out that top hub was binding with the case. It took like two days to get it in for some unbelievable reason. I think the prongs on my hub were very slightly bent, Honestly don't do this wrong, but, I tapped it in with a hammer and for sure it binded, Took it out and lightly sanded the hub. It took a very long worrisome effort but it went in and the trans worked well.
I am not the authority on this ut be sure it will go in AND turn fairly easy.
great car. Wrecked
Burnt Bonny.
great car. Wrecked
Burnt Bonny.
