2000 Pontiac Bonneville ssei intermittent stall, need help
golfyeti
- Posts like an LG3
- Year and Trim: 2000 SSEi
Re: 2000 Pontiac Bonneville ssei intermittent stall, need he
Bri, not sure if you still have that problem, or the car for that matter, but the problem you experienced sounds a lot like the one I had a few years ago. It turned out to be a faulty connector wire to the fuel pump, the one that comes down from the fuel pump and connects to the wiring harness behind the right rear wheel. Once replaced the totally random stalls went away. Too bad I had already replaced the fuel pump, LOL.
Mark
The Familyman's Trans-Am
bri00bonneville
- Year and Trim: 2000 Pontiac Bonneville SSEi
I still have it, it's just been setting for a few months. Cracked windshield, not cash to fix it right now to pass inspection :(. But it will be on the road within a month! I have checked all wires to the fuel pump, they seem fine. I've had a few problems with it not starting, so I pounded on the fuel pump, and it started right up. So I think it is the pump it self..
