Anyone else have this issue? Is there something else I can do to prevent this from happening?
I have Goodyear Eagle GT tires on the car...not sure if there are better tires or if certain tires are known not to seal very well.
I would NOT RECOMMEND using that 'fix a flat' goop....it threw my tire out of balance, further destroying it...total mess inside after...chisox.fan wrote:That's what I was afraid of. Some people told me to put some "fix-a-flat" inside the tire and that would help a bit. I don't know.
I had a rental that threw codes about tire pressure...The sensor on that car was part of the inflation valve assy. Not sure on my Bonne....chisox.fan wrote:Ultimately, I figure I'm going to need new wheels and I hesitate to get chrome wheels again. Is there anything certain I need to look for in wheels or any recommendations? I'm also not sure how switching wheels would work with the TPS. I haven't seen the TPS on my car but I assume it is attached the wheel somewhere.
you need a tire machine to remove the tire from the wheel.....safelytoomch wrote:Ok, this may be dumb but can a regular person take the tires off the wheels? Don't you need a machine? I've never tried it before.
