Hey guys....from the factory did they shim the starters on the 3.8 V6's?
Thanks,
Matt
89 Bonnville Starter Shim
twisted89le
- Year and Trim: 1989 Pontiac Bonneville LE 3.8 V6
Re: 89 Bonnville Starter Shim
Nope, you should not need a shim for these.
twisted89le
thanks!
If you bought a starter that needs shims I would take it back... The shims would tell me that the starter drive is not cut correctly and the shims are to correct for it... I have never shimmed a starter on any 3800...lol
Tim's Buick
I have, and its very common for most gm cars. The block is never machined that well. My sunfire has one shim from factory and the 2 others that I have take 2 shims. If replacing a starter listen to it. If it slips, you need to remove a shim, if it drags after starting (more common) you need to add a shim or 2.
09 Pontiac Vibe AWD
01 Pontiac Sunfire GTX
84 Chevrolet Citation
09 Pontiac Vibe AWD
I have owned 7 of these 3800 motors and never had a shim on any of them. My old 350, yes. I agree with Don.
1oldman
Hmmm - I've had to shim a starter on the old green monster. I guess it depends on where you get the starter from - BC
Its all about how the starter face is machined on the 3800's... I will not use a starter that has shims on a 3800... After installing dozens of starters on these engines I have never had any issues when using an AC Delco or the like quality starter..
