Replacing Air bag on wheel -- What bolt heads?
golfyeti
Every available option
Post by golfyeti »
I am assuming that to remove the driver air bag unit (this one already deployed) there are bolts tucked into the holes in the back half of the steering wheel. I can't see what kind they are, even with a mirror.
Can anyone confirm what type of screwdriver I need? Since I couldn't find one with a few search attempts, a link to a good step by step post would also be good if anyone knows one. Thanks
Mark
The Familyman's Trans-Am
Re: Replacing Air bag on wheel -- What bolt heads?
There aren't any bolts, they are spring clips that you have to release with a bent flathead screwdriver. Haro has a good picture of his tool for it.
