whos bought a uim for 3800?
david
Year and Trim: 2000 bonneville sle , 2002 gtp
Post by david »
So what did you buy and are you happy with it. Seen the Dorman kit and someone on here showed one with steel tube and bushing. Has anyone bought that set up and did it have everything gaskets ect ? This is for a 2000 Bonnie 3800 n/a. Thanks to all planning to buy one tomorrow.
What does it profit a man to gain the whole world and lose his soul.
ytd1861
Year and Trim: 2003 Bonneville SE -normally aspirated- 4 door
Re: whos bought a uim for 3800?
Post by ytd1861 »
I know the one from ZZ Performance does have all the gaskets, etc. because I emailed them the very same question yesterday. I've simply not ordered one yet.
D.T.
I bought this.
http://www.ineedparts.com/gm-intake-sur ... d-kit.html
Comes with everything you need.
david
Post by david »
never heard of the company. Who makes the uim? Dealt with cac much?
I can't say who makes the UIM I linked you, but I had this product next to a Dorman non-sleeved intake and build quality and solidity were spot on. Mine's been working perfectly fine since late August.
mylittleblackbird
Year and Trim: 1995 LX(went to the shredder)*sniffle*
1999 SE
Post by mylittleblackbird »
That sure fix manifold looks like an excellent deal, to be honest. Pre-sleeved UIM. If it comes with the gasket, you're hard pressed to beat the price. I'm still running on used UIM's that I acquired throughout my years of playing with L36's. I still have one good one left.
I have a Bonneville, it's white and N/A! :twisted:
Mod List: Hood and Fender "adjustment" - "Enhanced" A/C compressor clutch - Extra loud PS Pump - Mega sensitive CKPS - Audible Rear Drums - Lowered headliner - Custom stained upholstery - "Brown Devil" weight reduction kit - Low Friction Belt. More to come!
david
Post by david »
Thank you guys
Trinity
Year and Trim: 2002 SSEI "Twitch"
Intense LIII
Post by Trinity »
I just ordered this Dorman kit:
http://www.rockauto.com/catalog/raframe ... ttype=5536
Also, if you don't have the new aluminum LIM gasket on there, this is a great time to do that as well.
http://www.rockauto.com/catalog/raframe ... ttype=5424 AC Delco part 89017816
2002 SSEI "Twitch"
INTENSE™ Fenderwell Intake Kit
INTENSE™ Modular Pulley System with 3.40" Pulley -
SD Headers H-Flow Cat
WB 255 Siemens 60.0 (65.0) pound/hour Fuel Injectors
Yella Terra 1.9 90# Manley Retainers
L32 LIM & Gen V Blower N* TB
david
Post by david »
Well I ordered this kit http://www.ineedparts.com/gm-intake-sur ... d-kit.html ,now we will see how long it will take to get here. Will give you all feedback when I install it. Thanks again to all God Bless Dave
BonnevilleSE2000
Year and Trim: 2000 SE
Post by BonnevilleSE2000 »
Yeah I recently purchased the "Sure Fix" @ http://www.ineedparts.com/gm-intake-sur ... d-kit.html I have yet to have it installed, but I think that this is the best possible UIM kit.
Post by Jrs3800 »
nos4blood70 wrote:I bought this.
This is whats been on my 03 for the last 4 years... :)
Jfridge92
Post by Jfridge92 »
Yep, it's been running strong on the Buick for 3 years.
Joseph
1999 Infiniti G20T - Sold
Trinity
Intense LIII
Post by Trinity »
BonnevilleSE2000 wrote:Yeah I recently purchased the "Sure Fix" @ http://www.ineedparts.com/gm-intake-sur ... d-kit.html I have yet to have it installed, but I think that this is the best possible UIM kit.
You are going to pull the lower and have a look at it too right? If it has a plastic gasket you need to pull the lower and at least look at it. In fact, I would not do the upper without the lower unless it was an aluminum one.
2002 SSEI "Twitch"
david
Post by david »
Well got mine today. Took only 5 days to get it,hopefully I can find time this weekend.
crzydmnd72
Year and Trim: 1999 SLE
Post by crzydmnd72 »
count me in as another Sleeved one from Ineedparts, same as Carl and Don. 2 years ago
Glenn
1999 SLE 70k Stock for now
david
Post by david »
Well I installed it last night but do to the rain could not complete the job. Hopefully after church I can finish and turn it over. I really dont see the difference in the new and improved design. The metal sleeve really what does that do? Nothing touches it and is that were the uim fails? Thanks to all for the help.
david
Post by david »
a week later and still havent had time to put it all together.
david
Post by david »
Got it all done and it appears all is working ,just trying to take care of the other small stuff on the car.Next is the fuel gauge.
vogie01
Post by vogie01 »
crzydmnd72 wrote:count me in as another Sleeved one from Ineedparts, same as Carl and Don. 2 years ago
Same here. Had to swap out the injector o-rings again though. I have put almost 50,000 miles on mine and it is finally starting to show a little bit of leaking at one corner. Pretty impressed with how it has held up.
That's where the coolant to the TB goes. The stock EGR stovepipe gets much closer to that and melts it, causing coolant to leak in that area. The reduced diameter stovepipe plus the metal sleeve eliminate this problem.
