steering wheel controls
deano55
- Posts like an L36
anyone have a link to "how to remove and replace the radio controls on the steering wheel"? I sure can't find it
- patriottuba
- Year and Trim: 1999 Dark Green SLE
Re: steering wheel controls
Could someone find a page that concerns 96-99 steering wheel radio controls as well. One of the lights went out on mine. Thanks guys.
deano55
- Posts like an L36
No one has done this or has a link?
- 1tinindian
- Posts like an LG3
- Year and Trim: 2004 SLE Premier Edition
2005 GXP - Location: Rockford, Iowa
Remove air bag,
Unplug wire to switch,
remove switch.
I have removed the switch without removing the air bag, but the wires a pretty short.
Best to remove the air bag first.
You should also know something about disabling the SIR/SDM before messing around with the air bag.
Leon
remove switch.
Leon
- SSEiMan01
03 PAU - Location: DeKalb, IL
I have an airbag tool if it comes to that Dean. Maybe Haro knows a shortcut. He must have done it a billion times.
James May wrote:Hello.
I just use a bent screwdriver to release the airbag. I usually don't remove the airbag to swap buttons though.
- sandrock
- Retired Gearhead
I didn't have to either. Just a very thin screwdriver to use to pry the switches out of the wheel, and be careful not to pull too hard on the harness. Those wires are thin.
Interesting factoid...the Bonneville isn't the only one to use those pods. Grand Prixs, Grand Ams, and Montanas also used them. BUT the locating/retention tab on the back of the switches are different. I pieced together several of these pods to make a pristine set for my car.
deano55
- Posts like an L36
I was thinking you had to remove the torx screws from the back of the wheel, then they just pop off from the front then, that sounds good. Lets see what I break then
